POV-Ray : Newsgroups : povray.programming : 3D Trig Help for Bonehead needed Server Time
29 Sep 2024 12:19:42 EDT (-0400)
  3D Trig Help for Bonehead needed (Message 1 to 4 of 4)
Subject: 3D Trig Help for Bonehead needed
Date: 12 Sep 2000 12:07:23
Message: <39be54bb@news.povray.org>
I've got a simple question that's bugged me for years.  The answers got to
be simple, but I just can't figure it out.
I'm writing a C++ program to programmatically generate a Christmas tree and
I'm trying to put needles on the branches.  I have the start and end point
of the branch so I figured I would create the needles as if the branch
started at the origin and pointed straight up and then just translate and
rotate the union of the resulting needles so they actually appear on the
branch in the scene.  This translatation/rotation can occur in my C++ code
or the generated POV script, whichever is easier.
I've got an arbitary unit vector that reflects the orientation of the branch
(from VNormalize( ) in POV, or the good old Pythagorean distance function in
my C++ code), how do I turn that into an equivalent rotate < x, y, z >
statement so the needles end up on the branch?  I'm sure it's just the right
combination of atan( ) calls, but the details elude my addled brain.
Thanks for the help!
ric### [at] hiscom
Subject: Re: 3D Trig Help for Bonehead needed
Date: 13 Sep 2000 11:38:34
Message: <jerry-8875AC.08383513092000@news.povray.org>
In article <39be54bb@news.povray.org>, "Rick Gutleber" <ric### [at] hiscom>
>branch (from VNormalize( ) in POV, or the good old Pythagorean
>distance function in my C++ code), how do I turn that into an
>equivalent rotate < x, y, z > statement so the needles end up on the
>branch?  I'm sure it's just the right combination of atan( ) calls,
Honestly, it sounds like you're more advanced than I am so this probably
won't help, but I have a page that talks about using trig functions in
POV at http://www.hoboes.com/html/NetLife/POV/Trig/
Jerry
Date: 13 Sep 2000 23:58:03
Message: <39C04B05.969385E2@alumni.washington.edu>
First let me rephrase your question:
You have a generic branch aimed in a particular direction.  You want to
automatically reorient it to match branches on your tree.  The actual
position of the branches doesn't really enter into the picture here
because that is just translation, so we can simplify the problem to
changing the orientation.  Now, lets say your generic branch starts at
the origin, and ends at the point <Ax,Ay,Az>.  And you want to re-orient
it so that it ends at <Bx,By,Bz>.  Lets refer to these points as
vectors, A and B, and make one more simplification, that A and B are the
same length.
If this sounds like it describes what you want to do, it's the same
question I asked several years back, and John VanSickle provided a great
solution using Pov's generic matrix transforms.  He describes it on his
web page on matrices at
http://users.erols.com/vansickl/matrix.htm
(scroll down to the section titled "Rotating from one vector to
another")
I never muddled through it enought to understand the math behind it, but
it worked great for me at the time.
Hope that helps (credit goes to John),
Ken
> Rick
> ric### [at] hiscom
Date: 21 Sep 2000 15:17:07
Message: <39ca5eb3$1@news.povray.org>
Thanks, I got the same info from another newsgroup and it worked great.
Here's the catch:  I've been using POV since version 0.5.  A long time ago I
started writing C/C++ programs to generate POV scripts and I still do.  The
fact of the matter is that what I used to need C/C++ for can now be done in
POV.  I should really just port my program to a POV script, but for now it's
just easier to keep doing what I'm doing.
Thanks,
"Ken Cecka" <cec### [at] alumniwashingtonedu> wrote in message
news:39C04B05.969385E2@alumni.washington.edu...
> same length.
> another")
> Ken
to
and
point
and
code
branch
function in
right
> > Rick
> > ric### [at] hiscom
