POV-Ray : Newsgroups : povray.programming : Source Code again ! Server Time
2 Apr 2026 12:16:39 EDT (-0400)
  Source Code again ! (Message 1 to 8 of 8)
Subject: Source Code again !
Date: 29 Aug 2000 06:02:52
Message: <39ab8a4c@news.povray.org>
I have to find out how POV Ray calculate a ray. E.G. If i have a box or an
other object and i give them a light source: How can i find out what parts
of the C-Files are in use to calculate this process ? How reflect the
program this ray ? If u have any ideas how to start this difficult task
please write back..... Thanxs so far.
Mathias
Subject: Re: Source Code again !
Date: 29 Aug 2000 08:17:15
Message: <qqm66okz2gk.fsf@schlatt.fmi.uni-konstanz.de>
"Mathias" <Mat### [at] dlrde> writes:
The routine that calculates the intersection of a box and a ray is
Intersect_Box in boxes.c. For most POV objects there exists a c file that
contains the functions for this object type. If you don't have any clue
where to look, "grep" can help you:
grep -i box * | grep -i intersect
This command outputs all lines that contain "box" and "intersect" (ignoring
the lower and upper case). If you don't have grep or a equivalent program,
install one. Similarly to the above, the command
grep -i reflect * | grep -i ray
gives us the hint to look at the file "lighting.c" where we find the
function Reflect.
You probably already remarked that the calculation of a ray is distributed
over a lot of files. This is understandable, if you keep in mind how many
features the calculation of a ray might include (pigments, normals, object
types, reflection, refraction, media,...)
I hope this helps.
http://www.thomas.willhalm.de/ (includes pgp key)
Date: 29 Aug 2000 12:06:17
Message: <39abdf79@news.povray.org>
Mathias <Mat### [at] dlrde> wrote:
: I have to find out how POV Ray calculate a ray. E.G. If i have a box or an
: other object and i give them a light source: How can i find out what parts
: of the C-Files are in use to calculate this process ? How reflect the
: program this ray ? If u have any ideas how to start this difficult task
: please write back..... Thanxs so far.
  Somehow I got the impression that perhaps you haven't understood how
povray raytraces a scene. I may very well be mistaken, but do you think
that povray shoots rays from the light sources towards the objects and
then bounces them from the objects to the camera?
  If not, then just forget this question :)
Date: 29 Aug 2000 19:53:16
Message: <39AC4DDC.4C7F1433@mailbag.com>
Thomas Willhalm wrote:
> If you don't have any clue where to look, "grep" can help you:
Assuming Mathias has grep...
-Mark "Got grep?" Gordon
Date: 30 Aug 2000 03:01:36
Message: <39acb150$1@news.povray.org>
Then please tell me how povray raytraces a scene ? I dont know it.......
Mathias
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:39abdf79@news.povray.org...
an
parts
Date: 30 Aug 2000 04:12:46
Message: <qqmwvgznp4x.fsf@schlatt.fmi.uni-konstanz.de>
Mark Gordon <mtg### [at] mailbagcom> writes:
You are right: I should have looked whether he uses Windows (he does) and
provide a link like http://web.pncl.co.uk/~huw/grep/ .
Date: 30 Aug 2000 04:21:30
Message: <qqmsnrnnoqd.fsf@schlatt.fmi.uni-konstanz.de>
This is a question for the master of links...
As for hardcopies I have a (German) reference where (among other things)
the principles of raytracing are explained:
T. Rauber
Algorithmen in der Computergrafik
Teubner Verlag, Stuttgart
ISBN 3-519-02127-7
Date: 30 Aug 2000 18:40:35
Message: <chrishuff-E99EE5.17420930082000@news.povray.org>
In article <39acb150$1@news.povray.org>, "Mathias"
Hmm, I will try my best...at the most basic level, a raytracer works
this way:
For each pixel, it determines the direction and starting point of a line
going from that pixel to the portion of the scene visible from that
pixel. This is a "ray", an infinite line with a starting point and
direction. It then tests the ray against all the objects in the scene,
finding all(or a large number of) of the intersections it makes with
object surfaces. It usually does this by solving an equation. The
closest intersection found is taken as the first one, and the color of
the texture at that point is calculated.
To calculate reflections, it then determines a new direction for the
ray, based on the surface normal at the intersection point, and sets the
origin to the intersection point. It then "traces the ray" again, much
like the first ray, to get the contribution reflection makes to the
color of the surface. Refraction is done similarly, except the ior value
is also taken into account and a different calculation is used for
getting the new ray direction. Lighting is done by tracing a ray toward
a light source, and calculating the effect of transparent objects
between the object and light source on the light, or producing a shadow
if an opaque object is encountered.
Most raytracers use recursion, and go several levels deep into the
scene, so a ray can reflect or refract several times before stopping. In
POV, the maximum level is controlled by the max_trace_level keyword in
global_settings.
The exact way POV does things is much more complex, and follows a pretty
convoluted path through several source files, depending on the exact
features used and the portion of the scene currently being calculated,
and unfortunately, there is very little documentation on the source code.
Christopher James Huff
