POV-Ray : Newsgroups : povray.programming : Setting the render frame Server Time
15 May 2026 23:44:27 EDT (-0400)
  Setting the render frame (Message 1 to 4 of 4)
Subject: Setting the render frame
Date: 16 Aug 2000 11:18:09
Message: <399ab0b1$1@news.povray.org>
Hi folks,
I have some problems to set the render frame properly.
I use the FRAME structure and the parameters
Frame.Camera->Right
Frame.Camera->Up
Frame.Camera->Direction
The camera rotation and the angle of the camera lens (the angle of how much
you can see) determine the vectors Right and Up. Vector Direction has always
a length of 1. So, actually I stretch and rotate the frame but keeping
always a distance of 1 to the camera position.
But there's also the parameter
Frame.Camera->Angle
How do I have to set this angle and how does it influence my frame? Actually
this angle is already regarded in the frame vectors. So, do I really need
this angle???
Besides, can anybody tell me, what this parameters do?
 Frame.Camera->Blur_Samples = 0;
 Frame.Camera->Confidence = 0.9;
 Frame.Camera->Variance = 1.0 / 128.0;
 Frame.Camera->Aperture = 0.0;
 Frame.Camera->Focal_Distance = -1.0;
 Frame.Camera->Type = PERSPECTIVE_CAMERA;
 Frame.Camera->Tnormal = NULL;
Thank you in advance
Henryk
Subject: Re: Setting the render frame
Date: 16 Aug 2000 11:59:54
Message: <chrishuff-CAE65A.11010816082000@news.povray.org>
In article <399ab0b1$1@news.povray.org>, "Henryk Mueller"
> Frame.Camera->Angle
> Actually this angle is already regarded in the frame vectors. So, do
> I really need this angle???
The angle value is also used in later code, the create_ray() function in
render.c for example. I suggest you look at the camera parsing code in
parse.c for an example.
I can't really help you more without knowing what you are attempting to
do.
These are for focal blurring, I assume.
This tells what kind of camera it is, perspective, orthographic,
fisheye, etc.
This is simply the camera normal.
Christopher James Huff
Personal: e-mail chr### [at] maccom, Web page http://homepage.mac.com/chrishuff/
TAG: e-mail chr### [at] tagpovrayorg, Web page http://tag.povray.org/
Date: 16 Aug 2000 13:26:43
Message: <399aced3@news.povray.org>
Hi Chris,
> do.
Thank you for you fast help. The hint with parse.c was valuable.
But one other question: Why is the focal distance negative???
Ciao
Henryk
Date: 16 Aug 2000 13:43:56
Message: <chrishuff-4EFCE0.12450916082000@news.povray.org>
In article <399aced3@news.povray.org>, "Henryk Mueller"
To let POV know if a focal distance has been specified...look at the end
of the Parse_Camera() function in parse.c.
