POV-Ray : Newsgroups : povray.programming : Clipping Gradient Z Server Time
12 Nov 2025 00:26:13 EST (-0500)
  Clipping Gradient Z (Message 1 to 3 of 3)
Subject: Clipping Gradient Z
Date: 16 Aug 2000 10:13:10
Message: <399aa176@news.povray.org>
Explanation:  to generate realistic range images I need to create a Z based
pigment using the 'gradient' pigment modifier.
Problem:   'gradient' wraps from 0 to 1 continuously based upon a modulo
operation on Z, i.e. 'gradient' = fmod(z,1.0) where fmod = "floating point
remainder" in VC6++   (see pattern.c, void gradient for more details)
Question:   how do I force or modify gradient z so that it is valid only
from   0<Z<1 and gradient z = 0 otherwise?  If we can answer this question,
then creating random dot stereograms and producing other such range imagery
will become faster and more realistic using povray.  My only alternative at
this point is to clip the scene, which causes a 10X increase in compute
time.
#declare DepthMapTexture = texture {
      gradient z        // this little fellow keeps wrapping around with
increased z, i want to make him
      color_map {   // stop wrapping and return 0 when z > 1 and z < 0.
        [0.0 color Black]
        [1.0 color Red] }
      scale 40
  finish{ambient 1.0 diffuse 0.0}
Many Thanks! dan
Subject: Re: Clipping Gradient Z
Date: 16 Aug 2000 11:09:33
Message: <chrishuff-25573C.10104616082000@news.povray.org>
In article <399aa176@news.povray.org>, "dan"
> based pigment using the 'gradient' pigment modifier.
Why not just use the MegaPOV "depth" post_process filter?
> only from   0<Z<1 and gradient z = 0 otherwise?  If we can answer
> this question, then creating random dot stereograms and producing
> other such range imagery will become faster and more realistic using
> povray.  My only alternative at this point is to clip the scene,
> which causes a 10X increase in compute time.
You could use a function (in MegaPOV) specifying the blend you want,
clipping it to the correct range. If your entire scene is to be
contained within the range of the depth buffer, then you can simply
scale the gradient up to fit the scene.
Date: 16 Aug 2000 13:45:56
Message: <399AD353.8C0637EF@merlin.net.au>
> time.
>   pigment {
>         [0.0 color Black]
>         [1.0 color Red] }
>       scale 40
> Many Thanks! dan
Does 'planar' do what you want?
PoD
