POV-Ray : Newsgroups : povray.programming : Macro for ies-data? Server Time
29 Sep 2024 14:09:29 EDT (-0400)
  Macro for ies-data? (Message 1 to 6 of 6)
Subject: Macro for ies-data?
Date: 6 Aug 2000 05:09:47
Message: <398D2C98.5018@gmx.net>
Hi!
Do you think it is possible to write a macro which uses included
ies-data and creates an object of light-planes out of the data?
I think that povray light sources could represent an ies this
way, or do you think this would be impossible?
BTW, where to find information about writing macros? I know a bit
C / C++, and I used Povray some time ago, now I want to use it
again, but I need ies, so I would like to know if it will be
possible and where to get a good starting point.
Thank you, CU, Lars.
Subject: Re: Macro for ies-data?
Date: 7 Aug 2000 22:08:59
Message: <chrishuff-ACA42E.21095907082000@news.povray.org>
Uh, what is ies data? And what do you mean by "light-planes"?
They are easy to learn...just read the documentation, and look at the
macros which have been created. And if you have a specific problem, ask
on these newsgroups.
BTW, this group is for discussion of programming, this post would have
gone better in povray.advanced-users, povray.newusers, or povray.general.
Date: 10 Aug 2000 17:46:19
Message: <399323C1.5F22@gmx.net>
Hi Chris!
ies-files represent the light distribution of a source. This is
important if you want to simulate an architectural scene.
If there was a "parallel" area light in povray, one could write
the macro by modeling the light distribution with plane light
sources with different amplitudes.
I wonder if it makes sense to try something like this with a
sufficient amount of spotlights - though the "resolution" would
give bad performance.
I would like to try povray to simulate the behavior of some
materials in an interior scene, with the effects of different
light sources. At the moment this is impossible, as noone has a
real point light or spot light at home.
CU, Lars.
Date: 10 Aug 2000 18:07:16
Message: <chrishuff-2A2A6B.17081610082000@news.povray.org>
There are parallel lights in MegaPOV.
The large amount of lights would probably make things render very slowly.
You still haven't explained what format the ies data is in...is it some
sort of image map specifying the color and intensity of a planar light
source? Color and intensity over the surface of a patch or polygon? Or
simply a bunch of light sources? Does it store the geometry of the
scene, or just lighting?
It sounds like my pigmented light patch might be useful for this, I will
have to get back to work on it...
Date: 12 Aug 2000 18:44:53
Message: <3995D363.78C14227@club-internet.fr>
Lars wrote:
> Hi Chris!
I might have missed something. I remember having seen diagrams showing
the intensity of emitted light according to viewing angles. It was made
by a street lighting service in my company, and both depended on the
light source itself and the reflector. They used it in simulation tools
to study the resulting effet on actual buildings or bridges.
My suggestion would be (if the light source is small enough versus the
scene to avoid caustics issues) to use an extremely small transparent
sphere around your light source and to map a suitable filtering mask
around it.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 12 Aug 2000 18:58:41
Message: <chrishuff-9F5FA1.17594912082000@news.povray.org>
In article <3995D363.78C14227@club-internet.fr>, Francois Dispot
Something like the media scattering type diagrams in the POV manual?
Hmm, I wonder how difficult it would be to specify the falloff with a
spline...
