POV-Ray : Newsgroups : povray.programming : Background colours and antialiasing Server Time
19 Dec 2025 10:23:06 EST (-0500)
  Background colours and antialiasing (Message 1 to 10 of 12)
Subject: Background colours and antialiasing
Date: 31 Jul 2000 01:12:41
Message: <39850ac9@news.povray.org>
Hello all.
Lately I've been planning to raytrace a whole lot of graphics for a game I'm
making...  Antialiased pictures would be nicer, of course, but that leaves
the issue of which background colour to use for the rendering.
I think it would be nice to have an AA mode that does _NOT_ affect pixels
that touch the background, thus making AA pictures work fine with all colour
backgrounds.
I hope the above makes some sense!
I'm not sure whether this would mean a new AA mode (e.g. +AM3), or what, but
it would be very nice!
Thanks,
Edmund.
Subject: Re: Background colours and antialiasing
Date: 31 Jul 2000 01:57:58
Message: <39851540.7BB63FFA@yahoo.com>
isn't AA the blending and/or blurring of two colors along a sharp line?
unless it's possible to restrict AA to inside an object, making the
model color semi-transparent along the AA area, i don't see how this
could be done.
Edmund Horner wrote:
> Hello all.
> backgrounds.
> Thanks,
> Edmund.
Date: 31 Jul 2000 03:39:20
Message: <euaaosoiip6nq85g3o756bm0n3bo0sn86f@4ax.com>
On Mon, 31 Jul 2000 17:12:33 +1200, "Edmund Horner"
<ejr### [at] paradisenetnz> wrote:
>Hello all.
Use the alpha channel output (+UA with png or tga output). The alpha
channel, as POV interprets it, is an additional channel in the image
which represents the amount of "presense" in a pixel. The background
(or sky_sphere) get a 0 and a direct hit in an object gets 255.
Antialiasing does its job here, too, so anything in between 0 and 255
will happen on the edges of objects, which you find problematic.
Now, with the alpha channel output, you can open the graphic in a
paint program and defringe the edges so that the background color is
removed. In PhotoShop, you have to set the background to whatever it
is in your scene, open the file, load the alpha channel as a
selection, copy then paste to a new file, and then defringe.
If you don't have PhotoShop available, I am certain the GIMP or
PaintShop Pro have such abilities. If they do not, you can come up
with the same result using MegaPOV post-processing, but it will be
more tedious.
Peter Popov ICQ : 15002700
Date: 31 Jul 2000 03:48:52
Message: <39852F73.F504F18C@hotmail.com>
> Hello all.
> backgrounds.
Put one of the following in your commandline/ini file
Output_Alpha=bool ;Sets alpha output on/off
+UA ;Sets alpha output on
-UA ;Sets alpha output off
output
Read the docs for "File Output Options" and "Image maps" - down the bottom under
"Using the Alpha Channel"
You may or may not be able to use these formats & might want to export the alpha
channel as a greyscale image & remove it.
Hope this was of some help.
Bye
Pabs
Date: 31 Jul 2000 05:55:58
Message: <39854d2e@news.povray.org>
Thanks guys for the advice, I'm glad I can do it without resorting to
fiddling with the pov code.
"Edmund Horner" <ejr### [at] paradisenetnz> wrote in message
news:39850ac9@news.povray.org...
> Hello all.
I'm
colour
> backgrounds.
but
> Thanks,
> Edmund.
Date: 25 Aug 2000 07:15:28
Message: <39a65550$1@news.povray.org>
> The alpha channel, as POV interprets it, is an additional channel in the
So do pixels with a partial alpha channel (such as those on the edge of an
object) contain any colour from the background or skysphere?
I am about to create a tool that fixes the images I want from PNGs, so I
need to know if I can treat all non-zero alpha's as 255.
Date: 25 Aug 2000 07:40:43
Message: <39a65b3a@news.povray.org>
Edmund Horner <ejr### [at] paradisenetnz> wrote:
: So do pixels with a partial alpha channel (such as those on the edge of an
: object) contain any colour from the background or skysphere?
  Of course.
  If, for example, at a certain pixel due to antialiasing the color is 50%
the color of the object and 50% the color of the background, then the alpha
value will also be 50%. The color of the pixel will be a mixture between
the color of the object and the color of the background.
Date: 25 Aug 2000 09:54:28
Message: <39a67a94@news.povray.org>
So what do you think I can do to eliminate the background influence?
news:39a65b3a@news.povray.org...
an
>   Of course.
alpha
Date: 25 Aug 2000 16:25:19
Message: <39a6d62f@news.povray.org>
: So what do you think I can do to eliminate the background influence?
  Don't use antialiasing.
  I can't think of any other way. There's no way of antialiasing only the
sharp changes in color that do not take the background as one color (at least
not in any current povray).
Date: 28 Aug 2000 12:06:40
Message: <39aa8e10$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:39a6d62f@news.povray.org...
Or render against a black background. (The black, at least, won't taint your
colour when you eventually mix with your final background.)
Peter Harris
