POV-Ray : Newsgroups : povray.programming : Source to compile on BeOS Server Time
19 Dec 2025 11:56:39 EST (-0500)
  Source to compile on BeOS (Message 1 to 2 of 2)
Subject: Source to compile on BeOS
Date: 19 May 2000 18:30:11
Message: <3925c073@news.povray.org>
Want to compile povray on BeOS?
Visit http://www.newcolor.com/dswpov/  and grab the file dswpov-be.tgz
(Note: this web page is "under construction" and will be replaced by
something nicer, as soon as i'm done with my current animation project - i
hope by end of 2000!)
Start with unix povray source, available at www.povray.org.   Latest version
is 3.1g, which has been around for months.
Put the .tgz file in the /src subdirectory
Unzip and untar it to create a directory named beos2 which will contain a
makefile and sources.
There are no modifications necessary in the main povray source files.
Just type "make"
Resulting  povray is a command line version, with the new options  -D and -P
which work just like in unix.  Normally for a preview window, use both.
Omit both if you want hands-off rendering to a file.
Also you can say -D2 or -D3 ... up to -D9  to create a magnified preview
window - image and its pixels rendered at n times normal size.  Good for
rendering tiny images w/o magnifying lens.
This is "alpha" - may crash or act funny.
Others have also provided POV-Ray for BeOS.   So, here's another.  Why?  Why
not!   You may use the source any way you like, modify it, etc.
Daren Scot Wilson
dar### [at] pipelinecom
www.newcolor.com
Subject: Re: Source to compile on BeOS
Date: 20 May 2000 00:01:36
Message: <39260D22.20F6154@pacbell.net>
Hi Daren,
In case you are interested in running a comparison there is another
BeOS port of 3.1g available at -
http://www.bytepeople.com/beos/apps/povray.html
