POV-Ray : Newsgroups : povray.programming : math and trig question Server Time
2 Apr 2026 13:50:59 EDT (-0400)
  math and trig question (Message 1 to 9 of 9)
Subject: math and trig question
Date: 28 Mar 2000 15:21:41
Message: <38e11455@news.povray.org>
I have a question for a problem relating to 3D rotations.
I'm working on a bspline plug-in dll for Moray.  Its very close to being
ready for release once I get this small problem fixed.
So here it is:
I'm creating a tube like object for the spline by using a series of 'discs'
along the path of the spline and orientating its surface or normal to point
to the next joint or point along the spline.  Using the following math and
trig functions that Sean Worle provided:
  rz = atan2(dx, dy);
  rx = atan2(sqrt(dx*dx + dy*dy), dz);
atan2 = arctangent of y/x (in radians)
where dx, dy, dz are the differences between the current point and the next
point in the spline.
rz and rx are the amount to rotate the disc in the z and x axis.  The disc
is created in the X-Y plane.
The problem is when I create a b-spline object along the Z axis, which looks
like a straigt cylinder (or tube) - it is fine.  But if one of the points
moves in the x direction, then the disc is rotated by 90 degrees along the Z
axis which is not good.  But it does this because when using atan2 and the
dx goes negative it returns -90.
I certainly would appreciate any help.  I can provide pictures if needed.
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
Subject: Re: math and trig question
Date: 28 Mar 2000 18:17:48
Message: <38E13E2A.A5EF47B0@yahoo.com>
sorry, no math help here, but why are you using disks?  wouldn't spheres work?
rotation wouldn't matter then would it?
> So here it is:
>   rz = atan2(dx, dy);
> Mike
Date: 28 Mar 2000 19:34:53
Message: <38e14fad$1@news.povray.org>
I'm really using triangles, but to get the point across I use disc.
Triangles will be used to create the tube where one triangle's vertex will
be at a point on the circumference of the disc, and the two other vertices
of the triangle will be at two points on the circumference of the next disc
locate at the next point along the spline.
Mike
"ryan constantine" <rco### [at] yahoocom> wrote in message
news:38E13E2A.A5EF47B0@yahoo.com...
work?
> > So here it is:
'discs'
point
and
> >   rz = atan2(dx, dy);
next
disc
looks
points
the Z
the
needed.
> > Mike
Date: 29 Mar 2000 02:30:16
Message: <38E1B101.2D0E5474@umh.ac.be>
Your plugin is interesting! Send me more information, I will have
a look to this :).
Fabian.
> So here it is:
>   rz = atan2(dx, dy);
> Mike
Date: 1 Apr 2000 19:52:55
Message: <38e699e7$1@news.povray.org>
Love to help, thinking about it now...  I am half figuring it out, seeing
pictures would be good, emailing them directly to me fine.  Be
warned I'm not a programmer by nature, but a mathematics person,
so don't be surprised if I have no idea what a bspline is.
I think you don't want rotation in the z direction, as if the disk is created in
X-Y, then rotating it about Z, just rotates the circle, which is a symmetrical
object.  You want some y rotation instead.  If this isn't right I'll need some
more info.
I'm, thinking about it at the moment, I don't think the above would cause
that kind of a problem.
Date: 3 Apr 2000 12:23:33
Message: <38E8C44E.81C7E687@online.no>
Hello Mike
If I have understood your problem right, then I have had
similar problems myself.
I have tried to modify two of my POV-macros so that they
suit your problem.
See the code below for my solution.
If this is not what you need, then I will need more
information to solve your problem.
Tor Olav
mailto:tor### [at] hotmailcom
Because I don't master the C-language, my code is POV-ray syntax,
which is not very suited for a dll.
> So here it is:
>   rz = atan2(dx, dy);
I think you need to keep track of which quadrant you are in before you
apply the rotations. As far as I can see it, you loose that information
when you apply the formulas above.
Are you sure that it is wise to create your objects in the X-Y plane?
The torus object in POV-ray is always created in the X-Z plane.
And this may create problems for you if you want to "string up" toruses
instead of discs.
My original macros were made for tilting objects "created" in the X-Z
plane. (If you look in my recent posting to povray.text.scene-files
"Bumpy CSG-sphere" you will find these macros under the names:
vtilt & VectorAngles)
Wouldn't you have to accumulate up the rotations that is needed when
wandering from point to point in your spline?
#macro VA(Vector)
// Vector Angles
  <acos(vnormalize((x+y)*Vector).x)*(Vector.y > 0 ? -1 : 1),
   acos(vnormalize(Vector).z),
   0>
#end // macro VA
#macro VT(Thing, TVector)
// Vector Tilt
  #local RotateAngles = VA(TVector);
  object {
    Thing
    rotate  degrees(RotateAngles.x)*z
    rotate  degrees(RotateAngles.y)*y
    rotate -degrees(RotateAngles.x)*z
#end // macro VT
#declare dx = 0.2;
#declare dy = -0.3;
#declare dz = 0.5;
#declare TiltDirection = <dx, dy, dz>;
#declare OneBox = box { <6, 3, -1>/6, <-6, -3, 1>/6 }
#declare TiltedBox = VT(OneBox, TiltDirection)
object {
  TiltedBox
  pigment { color Red }
Date: 4 Apr 2000 00:38:51
Message: <38e971db@news.povray.org>
Tor,
Thanks for your input.
You POV code is similar to what I am doing. You are rotating only on the X
and Y axis and not the Z where I rotate only on the X and Z axis and not the
Y.  I'm  not familiar with the POV normalize instruction, but maybe I could
learn something from that.
Mike
Tor Olav Kristensen <tto### [at] onlineno> wrote in message
news:38E8C44E.81C7E687@online.no...
> Hello Mike
> suit your problem.
> Tor Olav
Not sure what you mean by that??
Mike
Date: 4 Apr 2000 12:04:52
Message: <38EA1167.DC358C7B@online.no>
Mike Weber wrote:
> Tor,
vnormalize multiplies the vector with a scalar
so that the length of the vector becomes equal
to 1.
This is done by choosing a scalar that is equal
to the reciprocal of the vectors current length.
I.e. if it is a 3D-vector:
1/sqrt(pow(Vector.x, 2) +
       pow(Vector.y, 2) +
       pow(Vector.z, 2))
Note that if Vector is a null-vector (e.g. <0, 0>
or <0, 0, 0>) then (in POV-Ray) vnormalize(Vector)
just leaves it as a null-vector.
While this expression would generate a warning
message if Vector is a null-vector (division
by zero):
1/(vlength(Vector))*Vector
If 3D-vectors were used, then my expression;
<acos(vnormalize((x + y)*Vector).x)*(Vector.y > 0 ? -1 : 1),
0>
could be written like this:
#if(Vector.y > 0)
  #local Sign = 1;
#else
  #local Sign = -1;
#end // if
<-Sign*acos(Vector.x/sqrt(pow(Vector.x, 2) +
                          pow(Vector.y, 2))),
acos(Vector.z/sqrt(pow(Vector.x, 2) +
                   pow(Vector.y, 2) +
                   pow(Vector.z, 2))),
0>
The last part could also be written like this
<-Sign*acos(Vector.x/vlength((x+y)*Vector)),
acos(Vector.z/vlength(Vector)),
0>
But with these two expressions one would have to
check if the x and y components were both zero.
> Mike
When using rotate in POV-Ray, the rotations is
always done around origo.
If you calculated this rotation relative to the
previous point (as is my understanding of your
description) and then applied the rotation relative
to origo, believe it would end up with a wrong
rotation relative to the previous point.
But if you take a copy of the object as it is
when it's rotated to the "last point" and then
applies the new rotations to make it point to
the "next point" then (I guess) it will become
right.
And my idea was that instead of making a copy of
the object as it was after it had last been copied,
you could just add together all the rotations that
had been done until the "last point" and then add
the new rotations to these rotations before
applying them to a copy of the object as it was
when created in your XZ-plane.
But again I don't know if my assumptions about
what you are really doing, is right. :)
...And maybe all my "believes" and theories
don't hold...
Tor Olav
Date: 4 Apr 2000 12:19:54
Message: <38ea162a$1@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:38EA1167.DC358C7B@online.no...
> > Mike
> right.
> don't hold...
No, you are correct.  Your ideas are very similar.  However, my object is
rotated at the origin (origo), then translated to the appropriate position.
The rotation is based on the angle between the the previous point and the
current point.
Mike
