POV-Ray : Newsgroups : povray.programming : Tesselating a 2D surface Server Time
16 May 2026 00:46:59 EDT (-0400)
  Tesselating a 2D surface (Message 1 to 8 of 8)
Subject: Tesselating a 2D surface
Date: 18 Nov 1999 17:37:19
Message: <38347f9f@news.povray.org>
Does anyone know of a (good) algorithm to tesselate a 2D polygon?
At least I think tesselation is what I'm after - what I want to do is
distributing points evenly inside a polygon with a certain maximum distance
to each other (that is, tesselate(d) should fill the polygon with enogh
points so that no points are more separated by more than d distance), and
then make a triangular mesh out of it.
Any ideas?
Subject: Re: Tesselating a 2D surface
Date: 18 Nov 1999 17:49:35
Message: <38348242.3056C3FA@pacbell.net>
> Any ideas?
You might find something useful at one of the sites listed here:
http://www.povray.org/links/3D_Resources/3D_solid_construction_methods/
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 18 Nov 1999 18:08:40
Message: <rYQ0OBVf7QYQALlBzAYLuRabU1h9@4ax.com>
On Thu, 18 Nov 1999 15:37:55 -0700, "Martin Magnusson"
>Any ideas?
Ideas, yes. Solution, no. That's how I usually proceed, anyway :)
Using baricentric coordinates you can place a number of points in the
polygon. Now set up a simple repulsive force among them and the edges
of the poly and either calculate a preset amount of "time" or until
the speed of all particles drops below a certain value. There *might*
be a procedural approach, and if there is, Ken will have most probably
found the link to it by the time I post this message. Oh well...
Peter Popov
ICQ: 15002700
Date: 18 Nov 1999 18:29:23
Message: <38348bd3@news.povray.org>
Say what?
That sounds like a good approach. It might take some time with 10000 or so
points, but then again, any algorithm will probably have to take some time.
Date: 18 Nov 1999 18:33:54
Message: <38348CA5.69C96D5@pacbell.net>
> Say what?
Barycentric \Bar`y*cen"tric\, a. [Gr. ? heavy + ? center.] Of or pertaining
to the center of gravity.
Date: 18 Nov 1999 18:38:23
Message: <38348def@news.povray.org>
>> Say what?
Ah, thanks!
Date: 18 Nov 1999 18:44:57
Message: <38348F3F.DC27BA24@pacbell.net>
> Any ideas?
http://xfactor.wpi.edu/Works/DCubanski/mva93h/subsection3_3_2.html
Date: 19 Nov 1999 17:12:17
Message: <3835cb41@news.povray.org>
Thanks a lot for your help. I love you guys!
