POV-Ray : Newsgroups : povray.programming : Memory? Server Time
12 Nov 2025 06:29:36 EST (-0500)
  Memory? (Message 1 to 6 of 6)
Subject: Memory?
Date: 8 Aug 1999 01:45:27
Message: <37ad1977@news.povray.org>
I have recently discovered that POV_MALLOC() is just a
container-function for the regular ANSI C function malloc().  Since when
has malloc() been able to access EMS?  In all my other C and C++
compilers, malloc() can only get space off the heap,  i.e. you are
limited to the base 640K.    Is this a Win95 issue? Or a flat-model
memory issue?     I expected to see complicated DPMI interfacing in the
source, and all I found was POV_MALLOC().   My question is: what is this
hidden memory "trick" that I don't know about.  Thanks,
Steve.
Subject: Re: Memory?
Date: 8 Aug 1999 03:21:58
Message: <37ad3016@news.povray.org>
In article <37ad1977@news.povray.org> , "Steve Horn <horn <dot> 74 @ osu"
Just a correct compiler setting and a good library allowing 32 bit
addressing under DOS - you are talking about DOS also the other question you
posted in this NG is Visual C++ related, right?
Or are you wondering about the difference between Win16 and Win32
applications?
    Thorsten
Date: 8 Aug 1999 07:00:57
Message: <37ad6369@news.povray.org>
"Steve Horn <horn <dot> 74 @ osu" <"dot> edu."> wrote:
: I have recently discovered that POV_MALLOC() is just a
: container-function for the regular ANSI C function malloc().  Since when
: has malloc() been able to access EMS?
  I think it doesn't. The compiler (djgpp, watcom or whatever) just calls
the dpmi driver which does the allocations. Since it works in 32-bit protected
mode, all the memory is available directly, without needing to use ems-pages.
  For example, this is entirely possible in djgpp and watcom:
malloc(100*1024*1024) /* allocate 100 Megs of memory */
  This works even if you have less than 100 Megs of physical RAM (the dpmi
driver creates a swap file).
  As I said, djgpp and watcom work in 32-bit protected mode, so there's no
64KB segment limits nor 640KB memory limit. You can allocate any amount
of any sized memory blocks (up to 4 Gigabytes). They don't call the DOS
memory allocation routines but the dpmi driver routines.
Date: 18 Aug 1999 15:37:40
Message: <37bb0a9c.23790166@news.povray.org>
Okay...that sounds good.  Now how can one get the amount of free
physical RAM left in EMS?   There seems to be no function in any of my
compilers to get this number.  (I have Borland Turbo C++ 3.0, MS Quick
C,  and MS Visual C++ v6.0... and Borland C++ 5.0 on disk not loaded
on my HD.)
Any suggestions?
Steve H.
Date: 19 Aug 1999 02:31:10
Message: <37bba4ae@news.povray.org>
Steve H. wrote in message <37bb0a9c.23790166@news.povray.org>...
protected
ems-pages.
>on my HD.)
Download the source code to Fractint and borrow the EMS/XMS assembly
routines from the general.asm file, or just include the general.obj file in
your project and call the EMS/XMS routines.
Mark
Date: 19 Aug 1999 04:55:13
Message: <37bbc671@news.povray.org>
Steve H.  <horn.74> wrote:
: Okay...that sounds good.  Now how can one get the amount of free
: physical RAM left in EMS?
  Don't confuse the term "EMS" with "memory above 1 MB". EMS is just a
standard/driver (?) to access the memory.
  No program uses EMS anymore. With EMS you can use just 64 KB of memory
at a time. For example, you can't allocate 1 Meg of memory and use it
directly.
:   There seems to be no function in any of my
: compilers to get this number.  (I have Borland Turbo C++ 3.0, MS Quick
: C,  and MS Visual C++ v6.0... and Borland C++ 5.0 on disk not loaded
: on my HD.)
  There's no standard way to do it. Sometimes it's even an ambiguous thing.
As I said before, you can allocate 100 Megs even if there's not that much
RAM in the machine. In this case memory is RAM+Hard drive space, which can
be up to 4 Gigabytes. Even if you could get the amount of free memory, that
doesn't mean that you can allocate that amount of memory without swapping.
