POV-Ray : Newsgroups : povray.programming : In theory...? Server Time
19 Dec 2025 15:12:55 EST (-0500)
  In theory...? (Message 1 to 1 of 1)
Subject: In theory...?
Date: 15 Jul 1999 12:16:31
Message: <378e095f@news.povray.org>
After seeing only a glimps of the possibilities of the isosurface and parametric
objects,
after using the extrusion macro's by Gilles Tran and Daniele Varrazzo,
after manually extracting a set of splines from a L-parser generated include
file,
and specialy after seeing Lummox' isoblob tree, I wonder:
1. In theory, would it be possible to extrude a set of splines straight into a
solid/primative object, without using triangles or bicubic patches?
2. In theory, would it be possible to use a spline as a blob component
(blobsweep)?
If no, then why, if yes, ... ehm ... then when ;-)
ingo
Met dank aan de muze met het glazen oog.
