POV-Ray : Newsgroups : povray.programming : POV-Ray source tutorials? Server Time
29 Sep 2024 18:14:24 EDT (-0400)
  POV-Ray source tutorials? (Message 1 to 7 of 7)
Subject: POV-Ray source tutorials?
Date: 20 Jun 1999 07:58:01
Message: <376CD841.E22FC493@compuserve.com>
Are there any tutorials or other sources of information on the POV-Ray
source yet? Like how to add a keyword, or explanations of the structure
of the source?
Subject: Re: POV-Ray source tutorials?
Date: 22 Jun 1999 19:00:31
Message: <3770162C.5C87@aol.com>
> structure of the source?
Not that I know of, though I've learned a little bit from working with
it in the few days I've had the source code myself.
To add a keyword, you must do the following:
- Add a token in TOKENIZE.C and PARSE.H, along with the other tokens;
  make sure it goes in the same place in both arrays.
- Add something in one of the Parse_suchandsuch() functions to recognize
  your keyword; there, do any secondary parsing you need, or else
  create a new Parse routine to handle it. (Look through PARSE.C and
  the Superpatch's F_EXPR.C to see what I mean.)
That's all I've learned so far. Not enough for me to create a new
primitive by any means, yet; in fact, I haven't created any new tokens
at all, though I've been tempted.
Lummox JR
Date: 22 Jun 1999 19:06:10
Message: <377015F6.E126304F@pacbell.net>
> of the source?
  Although I know if nothing currently available Chris Yound did mention
the following in his public message "Plans for Pov v3.1 and Beyond".
1) I will be writing an official technical document that describes the
POV-Ray language from a parser-writer's point of view.  It will include a
grammar specification using the syntax notation in our reference docs.  It
should be helpful to anyone who wants to implement their own parser.
  When he plans to release this to the public I cannot say but it should
prove a useful resource once completed.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 22 Jun 1999 20:07:57
Message: <37702658.131497B@compuserve.com>
a
It
should be helpful to anyone who wants to implement their own parser.<
That would be useful(although I hate that method of specification, I can
use it.). But what I really need is an explanation of the program source
code, not the scene description language.(There seem to be many
commented forms in the source to describe the various functions, but
most of them are empty!)
Date: 23 Jun 1999 17:12:32
Message: <jerry-2306991412310001@cerebus.acusd.edu>
In <377### [at] compuservecom>, Chris Huff
I'd recommend going to Ron Parker's web page at
http://www2.fwi.com/~parkerr/traces.html and download his "object bounds"
patch. It is one of the simplest patches I've seen (and also the most
useful for my work); once you've figured out how to install that, you
should have an idea of how to make another simple source patch.
Jerry
Date: 23 Jun 1999 17:22:03
Message: <37714ffb@news.povray.org>
It's fine as an example of modifying the tokenizer and the expression
parser, but it doesn't shed much light on the parser in general, or on
the hows and whys of adding textures and objects.
It's also a 3.0-only patch, so it's not even the state of the art (adding
tokens in 3.1 is much simpler.)
Date: 24 Jun 1999 15:24:40
Message: <jerry-2406991224400001@cerebus.acusd.edu>
I would recommend starting small...
Sure, but it is easy to use your 3.0 patch with 3.1. If I could do it,
anyone can.
Jerry
