POV-Ray : Newsgroups : povray.programming : UVPOV source questions Server Time
16 May 2026 02:57:33 EDT (-0400)
  UVPOV source questions (Message 1 to 3 of 3)
Subject: UVPOV source questions
Date: 17 Jun 1999 09:13:04
Message: <3768F553.3F9A116A@compuserve.com>
I have successfully compiled a Mac version of UVPOV, all I did was
replace the generic source files. Is there anything else I need to do?
Also, I got two compile errors, I commented out the two lines of code
that produced them, and all seems well, but are these important?
I have slightly tested the compile, and it seems to work fine.
compile errors:
(I thought these were generic sources?)
Error   : function has no prototype
TOKENIZE.C line 2096   WIN_WhereError (Token.Filename,
Token.Token_Line_No+1, Echo_Ptr, Echo_Indx, Token.Token_String) ;
Error   : function call does not match prototype
photons.c line 988   Warn(1.0,"Could not save photon map
(%s)\n",photonOptions.fileName);
Subject: Re: UVPOV source questions
Date: 17 Jun 1999 23:42:20
Message: <3769BF59.556DBC59@Kopp.com>
> compile errors:
This one's not important.  It's the line that tells the windows editor to
jump to the place where the error occured.
I think I forgot a header file for this one.  Looks like it's in PARSE.H
so if you include that file in PHOTONS.C it should solve the problem.
-Nathan
Date: 18 Jun 1999 18:04:50
Message: <376AC377.759C2F77@compuserve.com>
PARSE.H
I just tried that, and it doesn't seem to work. I just replaced the line
with one which didn't give photonOptions.fileName.
