POV-Ray : Newsgroups : povray.programming : Media Density and Color Maps Server Time
29 Sep 2024 20:14:49 EDT (-0400)
  Media Density and Color Maps (Message 1 to 9 of 9)
Subject: Media Density and Color Maps
Date: 16 Jun 1999 11:14:55
Message: <3767BC8C.D5544D2@pacbell.net>
Currently the only color modifications allowed in a media density
statment is by specifying a color map. Would it be possible to add
image mapping to this function allowing the color pallet of the
image used to effect the color density of the media ?
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Media Density and Color Maps
Date: 16 Jun 1999 11:28:52
Message: <3767c2b4@news.povray.org>
Yep.  It's a one-line change in parstxtr.c.  Works like a charm.
The only thing keeping it from working is that it is explicity
disallowed.  That's probably an oversight.
Date: 16 Jun 1999 12:08:45
Message: <3767C927.6DF7846B@pacbell.net>
  Strange they left that one out. Maybe there was not enough time to
document it before the version release but on a few occassions now I
have wished I could use this added feature.
Ken Tyler
Date: 16 Jun 1999 12:15:53
Message: <3767cdb9@news.povray.org>
I think it was just an honest mistake.  The error message is supposed
to apply to use of the image_map pattern in a normal block.  In older
code, normal and pigment were the only things that used patterns, so
it would have made sense to force image_maps to be inside pigment blocks.
Odd, though, that the other two cases of things that could only be used
in pigment blocks (color and color_map) were fixed and image_map was
not.
Date: 16 Jun 1999 13:54:36
Message: <3768e550.1223337@news.povray.org>
>not.
Does this mean yet another enhancement for a future version of the
Superpatch?
Later,
Glen Berry
Date: 16 Jun 1999 15:41:35
Message: <3767fdef@news.povray.org>
>Superpatch?
Could be.  In fact, the version I tested it on was a slightly-outdated
version of the superpatch.  I'll put it in between fixing that mesh
queue crash and figuring out a new version-numbering scheme sometime
this weekend.
Date: 16 Jun 1999 23:24:16
Message: <3767e6be.34304642@news.povray.org>
Currently, you can use the density_file pigment instead of planar
mapping. You can use PoD's tga2df3 utility to create the density file.
Keep in mind that a dimension of 1 in a .df3 crashes POV, so you'll
have to duplicate the input tga file to have 2 layers in the +z
direction of the .df3 .
Peter Popov
ICQ: 15002700
Date: 17 Jun 1999 00:54:36
Message: <376a7d31.40109544@news.povray.org>
>>Superpatch?
>this weekend.
I think a new version numbering scheme is an excellent idea. You've
been updating your software very diligently. It would be nice to have
a better way to tell if we have the most current published version.
Thanks,
Glen Berry
Date: 17 Jun 1999 04:29:06
Message: <qqm7lp3p6wi.fsf@goldach.fmi.uni-konstanz.de>
7no### [at] ezwvcom (Glen Berry) writes:
> >>Superpatch?
> >this weekend.
I second this. A unique version numbering for the superpatch would be
useful. I suggest to include the version number in the file names for
the binaries and the source code and print it while rendering.
http://www.fmi.uni-konstanz.de/~willhalm
