POV-Ray : Newsgroups : povray.programming : Problem compiling POV-Ray Mac Server Time
19 Mar 2026 12:04:01 EDT (-0400)
  Problem compiling POV-Ray Mac (Message 1 to 3 of 3)
Subject: Problem compiling POV-Ray Mac
Date: 14 Jun 1999 15:19:39
Message: <376556BA.8C371E91@compuserve.com>
I have downloaded the source code, but when I try to compile it,
CodeWarrior crashes(!?) when compiling targa.c.
I have a Power Mac G3 266 with 96 MB RAM, and CodeWarrior Pro Release 4.
Also, there is a file, apparently a project, called "POV.SPM.ppc.proj".
It has a blank icon, and CodeWarrior can't open it. I can give the file
type and creator codes if anyone wants.
Subject: Re: Problem compiling POV-Ray Mac
Date: 15 Jun 1999 11:53:23
Message: <376676f3@news.povray.org>
In article <376556BA.8C371E91@compuserve.com> , Chris Huff
You need to get the CW Pro 4.1 updates from the Metrowerks servers (you only
need the compiler, but I strong suggest to get all of them).  We didn't
update the docs because Meztrowerks advertises their fixes quite prominently
by a press release which makes it at least to macnn.com, mactech.com as well
as some (public) Apple developer newsletters. It is also advertised in the
CW docs :-)  Just go to the Metrowerks website and you will find the
updates.
If you check the modification date of this file, I think this is a very old
left over from Think C or an eraly CodeWarrior. I don't know how it got in
there (Eduard prepares the Mac 3.1 versions). I woul suggest to move it out
of that folder and rename it and compiling should still work - if so, then
just delete it.
e-mail: Tho### [at] csicom
Date: 16 Jun 1999 06:39:46
Message: <37677FE4.B1F550FB@compuserve.com>
Thanks, that helped, and now I can compile POV-Ray.
