POV-Ray : Newsgroups : povray.programming : A question about windows programming (C++) Server Time
12 Nov 2025 09:52:37 EST (-0500)
  A question about windows programming (C++) (Message 1 to 4 of 4)
Subject: A question about windows programming (C++)
Date: 5 Jun 1999 10:26:43
Message: <375933a3@netplex.aussie.org>
Not directly related to povray, but it's for an utility program that
I'm making.
  How do I redirect stdout and stderr to a text window inside my
application (just like povray seems to do)?
  I'm using borland C++ builder.
Subject: Re: A question about windows programming (C++)
Date: 5 Jun 1999 14:10:48
Message: <375a66f2.39667702@news.povray.org>
>I'm making.
I don't think POV does, exactly.  It uses a set of macros for all text
output.  If you look at the windows config.h, you'll see that it
points those macros at a series of WIN_* functions that send the
output to the message window.
In win32, you might be able to get away with pointing stdout and
stderr at an anonymous pipe, and having another thread emptying the
other end of the pipe into a window of some kind.
Date: 6 Jun 1999 10:37:35
Message: <375a87af@netplex.aussie.org>
Ronald L. Parker <par### [at] mailfwicom> wrote:
: In win32, you might be able to get away with pointing stdout and
: stderr at an anonymous pipe, and having another thread emptying the
: other end of the pipe into a window of some kind.
  How do I do that?
Date: 6 Jun 1999 14:07:52
Message: <375cb620.32158921@news.povray.org>
>  How do I do that?
I guess you start by reading up on threads and pipes.  I think the way
you create pipes is with CreatePipe.  Threads, of course, are a huge
subject.
Documentation on CreatePipe and other functions can be found at
http://msdn.microsoft.com/library/default.htm .
You'll have to use MSIE, though, because Embrace and Extend is alive
and well in the world of Java.
CreatePipe is under "Platform SDK > Base Services > Interprocess
Communication > Pipes" and the threading stuff us also under Base
Services, under "DLLs, Processes, and Threads"
