POV-Ray : Newsgroups : povray.programming : sine/cosine and exponents with animations? Server Time
29 Sep 2024 20:15:17 EDT (-0400)
  sine/cosine and exponents with animations? (Message 1 to 8 of 8)
Subject: sine/cosine and exponents with animations?
Date: 30 Apr 1999 05:20:54
Message: <372967e6.0@news.povray.org>
I've done some expirement animations with Povray, but have been missing a
couple of useful features. In order to make objects to move smoothly, the
object has to have a mathematical function that define the object's path.
Sine/cosine and exponent functions would be of great help there. Although
you can type "clock*clock" to make it a parabel, an exponent feature would
be much easier to use and it would also make possible to take the square
root (x^.5).
One other improvement would be an animation script through which you could
set individual enviroment for every frame of the animation.
For example: ball bouncing on th floor. The ball loses energy every time it
bounces from the floor (of course also in the air, but that's minimal) and
the maximal altitude lowers. A function which describes this is
y=<max.altitude>*sin x, where <max. altitude> is an individual value for
every bounce. It's value should be calculated for every bounce, not for
every frame.
This ball is one example, which would gain advantidge of all of those
features I'm missing:
1) sine function
2) ability to use exponent in scene language
3) a separate script file, which would control animation (for example:
calculate multipliers)
If someone has different solutions I'd gladly like to know about them.
Htl
Subject: Re: sine/cosine and exponents with animations?
Date: 30 Apr 1999 05:58:21
Message: <372970D4.6D3AE8FB@kolumbus.fi>
Lounento wrote:
> Hi,
> root (x^.5).
> every frame.
> 1) sine function
POV has this, RTFM
POV has this, RTFM
POV has this as of 3.1, if you have it then RTFM. Otherwise go get it
> Htl
I'm sorry but this is just a gross example of not reading the manual.
POV-Ray knows sin, cos and all that.
<Snippets from the manual>
cos(A) Cosine of A. Returns the cosine of the angle A, where A is
measured in radians.
sin(A) Sine of A. Returns the sine of the angle A, where A is measured
in radians.
pow(A,B) Exponentiation. Returns the value of A raised to the power B.
sqrt(A) Square root of A. Returns the value whose square is A.
<End snippet>
I didn't include the file handling routines, go read em yourself if you
need em. Please do read the whole manual :P
Date: 30 Apr 1999 09:09:31
Message: <37299d7b.0@news.povray.org>
Why don't you just read the manual?
Date: 30 Apr 1999 11:36:23
Message: <qqmpv4myy3d.fsf@goldach.fmi.uni-konstanz.de>
"Lounento" <som### [at] somewherecom> writes:
> root (x^.5).
Read the fine manual, in particular the section "Float Functions". Here's
an excerpt:
cos(A) Cosine of A. Returns the cosine of the angle A, where A is measured
in radians.
exp(A) Exponential of A. Returns the value of e raised to the power A where e
is the base of the natural logarithm, i.e. the
non-repeating value approximately equal to 2.71828182846.
sin(A) Sine of A. Returns the sine of the angle A, where A is measured in
radians.
and many other useful functions.
P.S.: I know that the Povray manual is huge and that one can easily overlook
a section.
P.P.S.: Please post your articles with real name.
http://www.fmi.uni-konstanz.de/~willhalm
Date: 30 Apr 1999 12:14:21
Message: <3729c8cd.0@news.povray.org>
>a section.
P.P.P.S.: Please post your articles in a relevant newsgroup.  This question
belongs in povray.newusers or povray.general.  povray.programming is for the
discussion of the POV source code (C code, not POV-script) and programming
discussions related to the writing of other POV utilities.
Date: 2 May 1999 10:07:17
Message: <372C4E17.DA9645A2@istar.ca>
> >a section.
This mistake is understandable, though... the description of this group on the
official POV site says: Programming with POV (incl. GUI Extensions)
Programming with POV can either mean programming FOR POV, as is interpreted by
the group, or programming IN POV, as was interpreted by the first poster.
It is something you cannot know a priori, only a posteriori.
I made this same mistake. As a matter of fact, I only realized specifically what
the group was for with this last post. I had also assumed it was both.
Ah well... maybe the description on the POV site whould be updated, save a little
confusion. :)
Simon
http://home.istar.ca/~sdevet
Date: 3 May 1999 09:10:01
Message: <372D9317.340C4238@puzzlecraft.com>
Hi Lounento,
If you want to code this stuff directly, then you should study the manual.
However, Chris Colefax has already written a macro ( ClockMod ) that does all
of this for you and I have written a tutorial on using the macro.
If you want to discuss the ClockMod macro further, post a message in the
animation group and we'll get you going bouncing balls that lose energy,
accelerations, decellerations, cyclics, all of it.
steve
Lounento wrote:
> Hi,
> root (x^.5).
> every frame.
> 1) sine function
> Htl
Date: 3 May 1999 09:20:57
Message: <qqmiuaagx92.fsf@goldach.fmi.uni-konstanz.de>
par### [at] my-dejanewscom (Ron Parker) writes:
> >a section.
Yes and no. If POV-Ray had had to be patched for a sin function, this would
have been the correct group. (I decided to answer in this group, because I
expected the discussion to be short and therefore not worth to direct to
another group.)
