POV-Ray : Newsgroups : povray.programming : GUIExt Interface for non C based compilers Server Time
2 Apr 2026 21:22:28 EDT (-0400)
  GUIExt Interface for non C based compilers (Message 1 to 3 of 3)
Subject: GUIExt Interface for non C based compilers
Date: 24 Jan 1999 03:32:20
Message: <36aada94.0@news.povray.org>
I am wondering if any one has examples of how to use the GUIExt interface
for programming languages other than C.
I am programming in Delphi (Object Pascal) and I would like to be able to
use the GUIExt Interface in a program I am producing. The only problem is
the source code for the GUIExt Example is in a language I don't know that
well and that is the only docs for the interface :-)
Would some one be able to help me understand the GUIExt interface so I can
make an interface to it for Delphi?
Once I do get an interface together I'm going to create a non visual
component for Delphi so that programmer's writting in Delphi can produce a
working interface to POVRay with two simple clicks of a button but that is
another story.....
Thanks for your help,
Christopher Fairbairn.
Subject: Re: GUIExt Interface for non C based compilers
Date: 24 Jan 1999 17:01:33
Message: <36AB420C.8E6AF9C7@xs4all.nl>
Christopher Fairbairn wrote:
> Hi,
> another story.....
This sounds like something I'm looking for. Please let me know if you get any
results.
Good luck,
Remco
Date: 26 Jan 1999 18:16:04
Message: <36ae4cb4.0@news.povray.org>
Christopher Fairbairn schrieb in Nachricht <36aada94.0@news.povray.org>...
>Hi,
>another story.....
I'm familiar with converting C to Object Pascal (I'm a - currently
inactive - Jedi member), and I'm glad to help you with that.
I was planning on doing the same (with the Moray plugin interface too).
I'll have a look at the source\windows\guiext files asap. I'll contact you
by e-mail if I have done something. You can also contact me via e-mail
(rve### [at] gmxnet) if you have questions of your own.
Rudy Velthuis
