POV-Ray : Newsgroups : povray.programming : uv mapping for arbitrary objects Server Time
29 Sep 2024 22:17:08 EDT (-0400)
  uv mapping for arbitrary objects (Message 1 to 3 of 3)
Subject: uv mapping for arbitrary objects
Date: 11 Mar 1999 04:07:50
Message: <36E787E5.560BFBD@ida.liu.se>
Hi!
I think I have an idea how to make "UV mapping" for
arbitrary objects. The current versions of it only
seem to work for bezier patches and a few other
objects (does it work with CSG?)
Please note that with "transformations" I mean
arbitrary nonlinear transformations of objects (CSG,
animated blobs etc...)
1. The user specifies the object before and after any
transformations and a few center points.
2. From the centerpoints a set of rays are shot out.
Where they intersect the untransformed object the
controll points c0,c1,c2,... are formed and where
they intersect the transformed object the controll
points c'0,c'1,... are formed.
3. When applying texture to a point <x',y',z'> on the
tranformed object write <x',y',z'> as a linear
combination of the few closest controlpoints
   <x',y',z'> = a * c'i +  b * c'j + d * c'k.
Calculate the "untranformed" point
      <x,y,z> = a * ci + b *cj + d * ck
And use the texture given at that point.
Example of how it could be used:
difference {
  sphere { <0,0,0>, 10 }
  sphere { <10,0,0>, 2 }
    transformed {
       original sphere{ <0,0,0>, 10 }
       original_centerpoints { <0,0,0> }
       center_points { <0,0,0> }
       control_density 10
    <my favourite texture....>
Of course this doesn't work with to few controlpoints,
to large transformations ,porly choosen "centerpoints"
or very irregular objects. But perhaps it works in most
normal cases with a smart user.
What do you think? Should I (try) to implement it?
/ Mathias Broxvall
Subject: Re: uv mapping for arbitrary objects
Date: 11 Mar 1999 18:21:21
Message: <36E84FB8.526C7A3E@Kopp.com>
This is an interesting concept.  Anyone know if there's any precedent for
doing this (any other renderers that use this technique)?  But might this
just become a form of spherical mapping?
-Nathan
Mathias Broxvall wrote:
> Hi!
> difference {
>   texture {
>     transformed {
>        control_density 10
> / Mathias Broxvall
Date: 12 Mar 1999 03:38:30
Message: <36E8D286.82ADE89C@ida.liu.se>
I wouldn't think it'd make a spherical mapping since in the degenerate
case when the transformed object is the same as the untransformed object
the texturing become the normal povray 3D textures.
As of the origin I was inspired of the uV mapping for bezier patches
(hmm... can any object be expressed as a set of bezier
patches/triangles...)
but I wouldn't be surprised if there already are renderes using this
technique.
/ Mathias
