POV-Ray : Newsgroups : povray.programming : lathe question Server Time
19 Dec 2025 18:38:49 EST (-0500)
  lathe question (Message 1 to 10 of 11)
Subject: lathe question
Date: 21 Feb 1999 04:25:59
Message: <36CFD2C8.225FE121@earthlink.net>
I am working on a model of a .223 Caliber bullet, when I use 1 povunit =
1 inch I get a weird 'squatty' bullet.  If I scale by <1,2,1> it looks
'right' why would I not get a correctly porpotioned image without
scaling it?  the image source below will generate 2 objects, left is
using actual measurements the right is scaled.
Source code:
#version 3.1
#include "metals.inc"
global_settings
  assumed_gamma 1.0
camera
  location  <0.0, 1, -9>
  direction 1.0*z
  right     4/3*x
  look_at   <0.0, 1, 0.0>
light_source
  <-30, 30, -30>
  color red 1.0  green 1.0  blue 1.0
#declare A223Round =
union{
  union{
    difference {
      cylinder { .001*y, .260*y .363}
      cylinder { 0*y, .260*y .169}
    lathe {
      linear_spline  10,
      <.373, 0>, <.373, .041>, <.325, .042>, <.327,.060>, <.372,.11>,
<.349, 1.436>, <.248,1.58>, <.248,1.76>, <.247, 1.76>, <.247, 1.58>
    texture{T_Brass_4B}
  lathe {
    linear_spline  7,
    <.222, 0>, <.222, .263>, <.223, .264>, <.17,.40>, <.06,.61>, <.02,
.6>, < 0,.5>
    texture{T_Copper_2B}
    translate <0,1.65,0>
object {A223Round translate <-1,0,0>}
object {A223Round translate <1,0,0> scale <1,2,1>}
Subject: Re: lathe question
Date: 21 Feb 1999 08:46:25
Message: <36D00DBC.E705B34D@pacbell.net>
 A look at the results and then a look at the lathe objects revealed
your scaling problem. The aspect ratio you choose for width vs. height
was off a factor 2:1. I basicaly increased the numbers in the right column
by twice their value for added height and adjusted the translation of the
projectile and it came a lot closer to what it should look like. This
was all quick shot in the dark changes and you will need to correct
a couple of niggly little steps I left in the code below before it will
look good.
 Sorry about the non indented script. I Can Not read a lathe or any other type
of multi point object withouth having it in columns. It adds clarity
to my perseption.
  lathe {
  linear_spline
  10,
  <0.373, 0.000>,
  <0.373, 0.081>,
  <0.325, 0.082>,
  <0.327, 0.120>,
  <0.372, 0.220>,
  <0.349, 2.436>,
  <0.248, 2.580>,
  <0.248, 2.760>,
  <0.247, 2.760>,
  <0.247, 2.580>}
  texture{T_Brass_4B}}
  lathe {
  linear_spline
  7,
  <0.222, 0.000>,
  <0.222, 0.463>,
  <0.223, 0.464>,
  <0.170, 0.800>,
  <0.060, 1.210>,
  <0.020, 1.200>,
  <0.000, 1.200>
  translate<0,2.75,0>}}
Ken Tyler
mailto://tylereng@pacbell.net
Date: 21 Feb 1999 09:00:58
Message: <36d0119a.0@news.povray.org>
Ken wrote in message <36D00DBC.E705B34D@pacbell.net>...
type
>to my perseption.
And indentation doesn't?! Ahh, forget it...
Margus
Date: 21 Feb 1999 09:30:09
Message: <36D017FC.470AE070@pacbell.net>
> type
> >to my perseption.
> Margus
Do you honestly think that Mark's format for the lathe is easier to read,
and visualize it's form, than the lathe format I provided ?
Ahh, forget it...
Ken Tyler
Date: 21 Feb 1999 09:49:51
Message: <36d01d0f.0@news.povray.org>
Ken schrieb in Nachricht <36D00DBC.E705B34D@pacbell.net>...
type
>to my perseption.
Now you were sooo close to make it really readable:
lathe {
  linear_spline
  10,
  <0.373, 0.000>,
  <0.373, 0.081>,
  <0.325, 0.082>,
  <0.327, 0.120>,
  <0.372, 0.220>,
  <0.349, 2.436>,
  <0.248, 2.580>,
  <0.248, 2.760>,
  <0.247, 2.760>,
  <0.247, 2.580>
  texture { T_Brass_4B }
 lathe {
  linear_spline
  7,
  <0.222, 0.000>,
  <0.222, 0.463>,
  <0.223, 0.464>,
  <0.170, 0.800>,
  <0.060, 1.210>,
  <0.020, 1.200>,
  <0.000, 1.200>
  texture { T_Copper_2B }
  translate<0,2.75,0>
Indentation is only there to show you the levels of a hierarchy, like in the
left pane of the Windows Explorer, ahhh... forget it.
Rudy
Date: 21 Feb 1999 09:56:15
Message: <36d01e8f.0@news.povray.org>
Alright, the lathe format looks better. But the rest of the code would still
be difficult to read without indentation (IMHO, at least).
Just as an example: my fur-generator's sampling script has
loops/conditionals nested 5 levels deep. I shudder to think what it would
look like without indentation...
Anyway, let's drop it.
Margus
Ken wrote in message <36D017FC.470AE070@pacbell.net>...
>Ahh, forget it...
>Ken Tyler
Date: 21 Feb 1999 19:57:27
Message: <36D0AD19.445C4369@earthlink.net>
Ken,
 I have to agree that the lathe object definitly looks better on columns!  thanks
for the hint.  I will still indent most code but the coordinates will be in
columns.:)
My problem is I used ACTUAL measurements of a round sitting here at the computer
with a dial caliper.  why do I need to double the height values?  shouldn't the
lathe take real numbers and render a 'real' looking object?
> look good.
> to my perseption.
>   lathe {
>   linear_spline
>   10,
>   <0.373, 0.000>,
>   <0.373, 0.081>,
>   <0.325, 0.082>,
>   <0.327, 0.120>,
>   <0.372, 0.220>,
>   <0.349, 2.436>,
>   <0.248, 2.580>,
>   <0.248, 2.760>,
>   <0.247, 2.760>,
>   <0.247, 2.580>}
>   lathe {
>   linear_spline
>   7,
>   <0.222, 0.000>,
>   <0.222, 0.463>,
>   <0.223, 0.464>,
>   <0.170, 0.800>,
>   <0.060, 1.210>,
>   <0.020, 1.200>,
>   <0.000, 1.200>
> Ken Tyler
Date: 22 Feb 1999 01:11:46
Message: <36D0AEC5.25BBD4D9@pipeline.com>
When I run into trouble like that, instead of fudging and running into worse
troubles later,  I would make a sphere, usually bright red or green, and see
how it looks.    In fact, in most of my scenes I have a section
#if (WantTestObjects)
sphere { <-5, -10, 0>, .5  pigment {<1,.3,.3>} finish{ambient.5 diffuse .5}}
...etc....spheres....cylinders....etc....
#endif
These test objects have high ambient values to make them show unnaturally
luminous, and have diffuse as a lighting check.  I catch a lot of weird scene
bugs by noticing funny lighting on my test objects.
My guess is your camera statement needs some adjusting.
Daren Scot Wilson
dar### [at] pipelinecom
www.newcolor.com
"A ship in a harbor is safe, but that is not what ships are built for"
                                            -- William Shedd
Date: 22 Feb 1999 08:18:46
Message: <36d15936.0@news.povray.org>
Mark Palmquist wrote in message <36D0AD19.445C4369@earthlink.net>...
>Ken,
thanks
>columns.:)
computer
the
I think I have your problem. With Lathe you enter the radius at the point in
question. Tou are directly measuring the object's diameter. Try dividing all
of the width numbers by 2 and that should fix your problem.
Rob
Date: 22 Feb 1999 09:33:42
Message: <36D16A52.E4ED6037@pacbell.net>
> Rob
I knew it had to be as simple as this. Good catch.
Ken Tyler
