POV-Ray : Newsgroups : povray.programming : True Diffraction Server Time
12 Jul 2025 13:22:16 EDT (-0400)
  True Diffraction (Message 1 to 10 of 12)
Subject: True Diffraction
Date: 8 Feb 1999 21:58:22
Message: <36BFA445.249A5943@bravo436.chem.mcgill.ca>
Does anybody have any thoughts about making a patch to add true
diffraction
to povray.  For example, the idea of double slit interfearence pattern
or the
diffraction of a pinhole (good-grief, Bessel functions!)  Or would
mathematical
optics (vs. geometrical optics) not be raytracing anymore?
I've never done much with pov except apply patches and trace scenes so
if anyone
has some idea, please let me know.
Carl Bartels, Department of Chemsitry, Mcgill University, to reply to
me,
just kill a and 5 from the email name, Montreal, QC, cAnAdA
Subject: Re: True Diffraction
Date: 8 Feb 1999 23:07:20
Message: <36c2b28e.3743771@news.povray.org>
On Mon, 08 Feb 1999 21:58:13 -0500, Carl Bartels
>diffraction
>or the
>mathematical
>if anyone
My brother and I were discussing the issue in the bus a couple of days
ago, just after his exam in radio waves and radio lines. We were
thinking of tracing spherical waves, but then we thought the wave can
be represented by rays and the wave equation for these rays. More
precisely, monte carlo rays in all directions, more rays where needed
(slits, edges, wedges, gratings, etc.) Interference is easy to model
this way but it requires backward raytracing. Tropospheric refraction
is also easy to model. Hydrometeoric scattering is somewhat difficult
to imitate and virtually impossible to implement realistically. Then
we was we had missed the busstop...
Peter
Date: 9 Feb 1999 05:19:59
Message: <36C00AFF.93F2F37@aol.com>
I have a book that talks about diffraction gratings.  Says a typical one
has 14,000 to 15,000 rulings per inch and that for maximum efficiency
the seperation of them should be on the order of 1/50,000 inch, or about
the wavelength of light.
I would think aliasing would be a problem. ;)
-Mike
> diffraction
> or the
> mathematical
> if anyone
> me,
Date: 9 Feb 1999 10:55:55
Message: <36C05A4A.F28CD725@pacbell.net>
> -Mike
Wouldn't that depend on how far the camera were placed from the surface ?
Ken Tyler
mailto://tylereng@pacbell.net
Date: 9 Feb 1999 19:23:14
Message: <36C0D164.66A25154@bravo436.chem.mcgill.ca>
Well, that's because of what they are designed to do.  One big use is in
spectroscopy where they want a nice reliable, computable relationship
between the angle of deflection and wavelength.  Prisms don't cut it
because the dispersion isn't a linear (or anything else) function of
wavelength.  Diffraction off that sort of grating is very well defined
though.  But you don't need a grating.  Find your local gadget freak and
try to borrow their laser pointer.  While you're at it, yank one of
their hairs out.  Now find a white wall and blast the laser at the wall
and stick the hair in the way.  You get the main spot from the pointer,
but also some nifty satelite spots on either side.  Or, try flashing it
off a CD and see how many spots you get.  That's the sort of thing I'm
talking about.
My guess is that it would have to deal with things in two ways.
Diffraction due to the shape of some small, individual object (hair,
pinhole, etc.) and diffraction due to a grating type texture that would
treat things like the opalescence does now.
me,
Date: 9 Feb 1999 21:29:25
Message: <36C0EF4F.EE512811@Kopp.com>
> > -Mike
> Ken Tyler
How close do you want to get?  ;-)
Seriously... doing this kind of diffraction would be very difficult.  First,
as someone else mentioned, it would require backwards ray tracing.
Secondly, it would require modeling light as waves instead of particles.
The ray-tracing model can be visualized as lots of tiny particles flying
through space.  I'm not sure how you'd change this model to incorporate
expanding wavefronts.
If anyone has any ideas, I'd be interested to hear them.  Keep in mind
the very small size of these objects/slits that will be causing
diffraction, and how dense you would need to trace rays in order to
guarantee enough rays going through the slit or getting close enough
to the strand of hair.
Also keep in mind the (amount of work):(amount it affects an image)
ratio.  ;-)
-Nathan
Date: 10 Feb 1999 00:22:56
Message: <36c2135b.3559612@news.povray.org>
On Tue, 09 Feb 1999 21:30:39 -0500, Nathan Kopp <Nat### [at] Koppcom>
>ratio.  ;-)
>-Nathan
You don't need to model waves (id est, trace spheres) and you can't. A
spherical wave has infinitely many intersection with a plane, the ones
cophasal forming ellipses. OTOH, if you trace rays and remember that
not only x,y and z, but also phi (phase shift) are functions of t. So
for interference, once you've told the program where the slit is, it
will trace it's bounding box with a number of rays and then treat the
rays hitting the edges of the slit (in an epsilon vicinity) as
secondary sources. Now if you look at the screen (i.e. send a camera
ray to it) you'll see that is is lit by these secondary light sources
(or photons if you wish :) ), but if you keep in mind phase shifts you
can correctly calculate the total light intensity at a point, i.e. get
minima and maxima. Same counts for diffraction (what are 100000
photons for Pete's sake? :) ), if the program knows where the grating
is and how dense, it could send a ray per aperture quite precisely.
Hair, too. In summary, you don't want diffraction etc. patterns
throrought the whole pic, so concentrate the rays where you know you
need them.
Another problem is wavelength. While one can specify it implicitly for
the aforementioned purposes, it is needed for dispersion, Rayleigh
scattering, etc. I have given thought to this and even tried to find
away to Fourier-analyse rgb components :) (I was young and naive then,
now I'm only young), but gave up and concluded that simple sampling
will be easier. Someone else found this before I did (Greetings Mr.
Wilson ), it seems. I thought that, instead of rgbf colours, light
spectrum could be used (like a color_map, but shows the intensity and
absorption of light for different wavelenghts), but then again,
nobody's *that* crazy to use this things.
Well that's my 35lv on the topic.
Peter
Date: 11 Feb 1999 00:26:04
Message: <36C26A31.B9F85D0D@Kopp.com>
I just added (to my photon mapping stuff) an option to define a light's
color as a color_map, replacing the single color.  This color_map
defines all of the frequencies/intensities inside the single light, so
that it is properly split up when it hits an object that causes
dispersion.  It's neat, because you can have one scene where a yellow
light gets split into red and green, and another where the same yellow
stays yellow (pure yellow wavelength).
-Nathan
Date: 11 Feb 1999 00:48:22
Message: <36C26EEC.2C30E68B@pacbell.net>
> -Nathan
  Does this take into account color temperature as measured in kelvins ?
Ken Tyler
Date: 11 Feb 1999 13:30:24
Message: <36C32204.9488C681@Kopp.com>
Probably not.  The code does an RGB->HSV conversion, uses the hue as
an estimate of wavelength, and then uses one of DSW's routines to find
the new IOR for that wavelength.  It's all kind of faked (not real
physics, AFAIK).
-Nathan
