POV-Ray : Newsgroups : povray.programming : splash! Server Time
30 Sep 2024 00:11:05 EDT (-0400)
  splash! (Message 1 to 3 of 3)
Subject: splash!
Date: 23 Jan 1999 17:07:32
Message: <36AA47BF.727EA2B8@xs4all.nl>
I'm new to the combination programming/POVray so this may be a stupid question.
I'm trying to make a simple program that uses POVray for some small testrenders.
Everything works fine in that I get POV to render the file using the
commandline. I'd like to keep the rendering on the background and that also
works except for the splash-screen. Is there a way to avoid the splash to appear
with every render?
I'm using Delphi, not hacking any POV-code and I wouldn't want to make it too
complicated.
Thanks for any information.
Remco
Subject: Re: splash!
Date: 24 Jan 1999 06:15:16
Message: <36ab00c4.0@news.povray.org>
Well...
You could use the DOS version in a hidden window (it doesn't have a
splashscreen, does it?)....
Or instead of restarting POV (where you will get the splash-screen each
time), use the existing GUI extension hooks and simply send new render
commands to the already running instance of POV (like for example Moray
does). This way you get the splash screen only with the first render.
Johannes.
Remco de Korte wrote in message <36AA47BF.727EA2B8@xs4all.nl>...
question.
testrenders.
appear
>with every render?
too
>complicated.
>Regards,
>Remco
Date: 24 Jan 1999 10:52:32
Message: <36AB41C6.BA242685@xs4all.nl>
Johannes Hubert wrote:
> Well...
> Johannes.
Okay, I get that, but "GUI extension hooks" is nothing more then a couple of
words to me. As I said I'm totally new to this so I have no idea where to start.
Still, isn't it at all possible to start POV, with a commandlineswitch or
something, without the splashscreen?
The DOS-option is a good one too, come to think of it...
Thanks,
Remco
