POV-Ray : Newsgroups : povray.programming : Help using File IO for animation Server Time
19 Dec 2025 20:19:18 EST (-0500)
  Help using File IO for animation (Message 1 to 1 of 1)
Subject: Help using File IO for animation
Date: 12 Nov 1998 23:29:55
Message: <364bb5c3.0@news.povray.org>
Does anyone know if I can use the File IO directives in the following
manner.
I have an ASCII file table of parameters where each row represents one frame
and each column is a parameter used in a POV file.
I'd like to use the File directives to read one line from the file for each
frame rendered.
Can the same #fopen file handle span across multiple frames? Or must the
file be reopened each pass and #read performed in order the reach the
correct frame line?
Thanks in advance,
Winefred
