POV-Ray : Newsgroups : povray.programming : GUI Question Server Time
16 May 2026 06:28:23 EDT (-0400)
  GUI Question (Message 1 to 2 of 2)
Subject: GUI Question
Date: 2 Oct 1998 02:19:57
Message: <3614627d.0@news.povray.org>
Does anyone know if it's possible to control POV-RAY's clock variable via
the GUI Extensions API.
Thanks in advance,
Winefred
Subject: Re: GUI Question
Date: 2 Oct 1998 07:43:02
Message: <3614aaff.1198199@news.povray.org>
You can set the clock variable via the command line by "+k", so you
can set it with for example like this
  ExternalVarStruct tVars;
  unsigned char bReturn;
  tVars.RecSize = sizeof(ExternalVarStruct);
  strcpy(tVars.command_line, "+k3.4");
  bReturn = (*Instance->Request) (RequestSetVars, &tVars);
if you want to ADD the clock variable to the commandline, you have to
get the commandline first by
  bReturn = (*Instance->Request) (RequestGetVars, &tVars);
and then cat the clock variable to it before setting it again with
I hope this is o.k. and helps,
Friedemann
Friedemann Schmidt
F.S### [at] fhtw-berlinde
Raytracing-Gallery: http://www.rz.fhtw-berlin.de/~s0049669/
