POV-Ray : Newsgroups : povray.programming : sphere scaling bug Server Time
12 Jun 2026 07:04:04 EDT (-0400)
  sphere scaling bug (Message 1 to 8 of 8)
Subject: sphere scaling bug
Date: 19 Sep 1998 22:51:13
Message: <36045E84.18242E1E@ltu.edu>
Ok... there seems to be a bug in POV's sphere scaling code.  If you have a
sphere and you scale it uniformly, it will simply multiply the radius by your
scale factor instead of using a transformation matrix.  This is a speed
improvement under some circumstances, but it seems to lead to a bug when
the radius is veryu small.  Also, starting with a small radius leads to the
same problem.  the sphere gets smaller than it should.  Below is code that
shows two spheres lined up on the x axis.  The sphere on the right is
scaled by 0.005, while the sphere on the left is scaled by
<.005,.005,.00501> This forces the sphere on the right to use the
transformation instead of a very small radius, so it renders properly.
This is getting sent to Chris Young and to povray.programming.
-Nathan Kopp
// This scene was originally generated by Moray.
background { color <0.000,0.000,0.000> }
camera {  //  Camera StdCam
  location  <      0.000,     -25.000,       0.000>
  direction <        0.0,         0.0,   1097.8478> // Aperture is 0.07 degrees
  sky       <    0.00000,     0.00000,     1.00000> // Use right handed-system
(rotated by 0.00 degrees)!
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.33333,         0.0,         0.0> // Aspect ratio
  look_at   <      0.000,       0.000,       0.000>
light_source {   // Light1
  <0.000, -20.000, 20.000>
  color rgb <1.000, 1.000, 1.000>
#declare Texture1 =
   texture { pigment {  color rgb <0.0, 1.0, 0.0>  } }
sphere { // Sphere001
  <0,0,0>,1
  texture { Texture1 }
  scale 0.005
  translate  0.005*x
sphere { // Sphere2
  <0,0,0>,1
  scale <0.005, 0.005, 0.00501>
  translate  -0.005*x
Subject: Re: sphere scaling bug
Date: 20 Sep 1998 12:16:19
Message: <36051c43.0@news.povray.org>
In article <36045E84.18242E1E@ltu.edu> , Nathan Kopp <nk8### [at] ltuedu>  wrote:
>-Nathan Kopp
This is interesting! On my Mac it renders OK!!! Obviously this is a precision problem
because it I decrease the size by a factor of ten, I get (finally) the same problem.
Thorsten
PS: Now it is proven! The Macintosh is better for rendering than a PC!!! :-)
Date: 20 Sep 1998 15:37:13
Message: <36084720.225653302@news.povray.org>
On Sat, 19 Sep 1998 21:46:45 -0400, Nathan Kopp <nk8### [at] ltuedu>
Here's the culprit, from the windows config.h file:
#define EPSILON 1.0e-5
I changed this to
#define EPSILON 1.0e-12
and, for good measure, added
#define SNGL double
#define COLC double
and the problem went away.
Date: 20 Sep 1998 15:57:16
Message: <36054EFD.CC5302A4@ltu.edu>
Sorry, I forgot to mention that this was with POV-Ray for WINDOWS.  One thing
that I'm interested in, too, is how much of a speedup the multiply-the-radius
optimization provides.  Although I guess that when it comes to ray-tracing,
any little speedup helps!
-Nathan
> I changed this to
> #define SNGL double
> #define COLC double
Date: 20 Sep 1998 16:01:42
Message: <360a501e.227954931@news.povray.org>
On Sun, 20 Sep 1998 14:52:45 -0400, Nathan Kopp <nk8### [at] ltuedu>
Erm... my fix was for pov-ray for windows, too.  Look in the windows
directory for a file called config.h.  Change epsilon and add those
other two #defines.  Recompile.  Your spheres now render the same
size.  But who knows why epsilon was so big or what else this change
might break in heightfields etc.
Compared to using an ellipsoid intersection routine, I suppose the
speedup is probably pretty good.
Date: 20 Sep 1998 17:51:56
Message: <36056a6f.234692888@news.povray.org>
On Sun, 20 Sep 1998 18:59:56 GMT, par### [at] mailfwicom (Ronald L.
Oops... changing COLC to a double breaks Moray's preview.  Better
leave that one alone.
Date: 20 Sep 1998 22:40:41
Message: <3605AE9D.E638F232@flash.net>
> I changed this to
Funny : I was just looking over the UNIX code earlier today and
was pretty sure on that system EPSILON was 10^-10 .  It didn't exhibit
the scaling bug, which I had no problem producing on my Windows versions.
But there is another issue, which is how the calculation is done.
A segment of spheres.c follows:
> int Intersect_Sphere(Ray, Center, Radius2, Depth1, Depth2)
> RAY *Ray;
> VECTOR Center;
> DBL Radius2;
> DBL *Depth1, *Depth2;
>   DBL OCSquared, t_Closest_Approach, Half_Chord, t_Half_Chord_Squared;
>   VECTOR Origin_To_Center;
>   Increase_Counter(stats[Ray_Sphere_Tests]);
>   VSub(Origin_To_Center, Center, Ray->Initial);
>   VDot(OCSquared, Origin_To_Center, Origin_To_Center);
>   VDot(t_Closest_Approach, Origin_To_Center, Ray->Direction);
>   if ((OCSquared >= Radius2) && (t_Closest_Approach < EPSILON))
>     return(FALSE);
>   t_Half_Chord_Squared = Radius2 - OCSquared + Sqr(t_Closest_Approach);
>   if (t_Half_Chord_Squared > EPSILON)
>     Half_Chord = sqrt(t_Half_Chord_Squared);
>     *Depth1 = t_Closest_Approach - Half_Chord;
>     *Depth2 = t_Closest_Approach + Half_Chord;
>     Increase_Counter(stats[Ray_Sphere_Tests_Succeeded]);
>     return(TRUE);
>   return(FALSE);
Note the test : t_Half_Chord_Squared, of order distance^2,
is compared to epsilon.  I would expect a test of the following
form might be less prone to scaling artifacts :
>   if (t_Half_Chord_Squared > EPSILON * Radius2)
or, equivalently (and faster) :
>   t_Half_Chord_Squared_N = 1 - (CSquared + Sqr(t_Closest_Approach)) / Radius2;
>   if (t_Half_Chord_Squared_N > EPSILON)
>   Half_Chord = sqrt(Radius2 * t_Half_Chord_Squared_N)
There are many other ways in which one could try and preserve scale
invariance of these tests.
Dan
http://www.flash.net/~djconnel/
Date: 21 Sep 1998 15:35:37
Message: <36069B64.E3BBED09@ltu.edu>
Yes... I just wanted to make sure everyone else knew that I noticed it in
Windows and that other platforms may not have the same problem... but it
looks like everyone figured that out anyway.  :-)
I have a feeling that changing SNGL to a double might also cause problems
with GUI extensions, but I'm not totally sure.
-Nathan Kopp
