POV-Ray : Newsgroups : povray.programming : Sun Solaris v2.6 Server Time
19 Mar 2026 19:10:39 EDT (-0400)
  Sun Solaris v2.6 (Message 1 to 1 of 1)
Subject: Sun Solaris v2.6
Date: 4 Sep 1998 16:43:14
Message: <35f042d2.0@news.povray.org>
Thought someone might be interested in the following information.
I set up a Sun Ultra Sparc workstation as follows
HARDWARE:
    Dual sparc 168mhz processors with sparc floating point processors
    128Mb of memory
    12Gb of Disk space
OPERATING SYSTEM:
    Sun Solaris v2.6
    Common Desktop Environment v1.0 (Now available with Solaris v2.6)
COMPILATION COMPONENTS:  (All built specifically for
sparc-sun-solaris2.6)
    gcc v2.8.1
    binutils v2.8.1
    gdb v4.16
    make v3.76.1
    libstdc++ v2.8.1
POVRAY SOURCE v3.02   (also compiled compression tools that came with
POV-Ray Source)
I built the x-povray version of the product with little trouble.  I
built a Sun Package (using pkgmk) to install the POV product in
/opt/local/ which is the preferred location for 3rd party products for
Solaris.  This makes the pkgadd and pkgrm of POV-Ray from a Sun box
effortless.
My testing of the POV engine has had zero problems and the POV x-povray
works well with the CDE (Common Desktop Environment).  I've tested the
program with several sustained, simultaneous animation renders.  Here's
some numbers I've come up with.
A single 62 frame animation render outperformed an Intel (PentPro
180mhz) by 33% (Sparc was 33% faster).  The Ultra-Sparc render reported
more sampling, but I could not tell any significant difference in the
resulting avi file.
Muliple, simultaneous animation renders (3 scenes ranging from 48 to 62
frames) buried the Intel, but the Ultra-Sparc showed no signs of
slowing.  (I may try adding additional simultaneous renders to see when
the Ultra slows when I get time)
Obviously, anyone would expect a Dual Sparc to outperform Intel.  I
report the results as a "Frame of Reference".  Does anyone have a
suggestion where I could look in the POV source to get even more
performance out of the Solaris v2.6 build?  I mean something simple,
like a header setting or compile option.
McNaul
Download 'iso-8859-1' (4 KB)
