POV-Ray : Newsgroups : povray.programming : Re: POV-Ray memory bugs. Server Time
16 May 2026 07:36:33 EDT (-0400)
  Re: POV-Ray memory bugs. (Message 1 to 5 of 5)
Subject: Re: POV-Ray memory bugs.
Date: 25 Aug 1998 00:47:00
Message: <35E23309.3238A749@ltu.edu>
I heard that this was a only problem with the Windows version... are there
any UNIX (or other) people out there who can confirm/deny this rumor?
-Nathan
Date: 25 Aug 1998 04:11:22
Message: <qqmww7x4jtx.fsf@goldach.fmi.uni-konstanz.de>
Nathan Kopp <nk8### [at] ltuedu> writes:
> -Nathan
Perhaps you know the tool "purify". It checks the usage of memory and finds
almost every error. I've just used it with POV-Ray to render a scene that
uses more than 60 MB on a Sun Enterprise. There wasn't any memory leak - not
a single byte. The scene contains spheres, cylinders, bezier patches and a
plane. At least these features seem to work perfectly.
However, you may want to send me a scene that causes problems on a Windows
machine, and I will check it.
http://www.fmi.uni-konstanz.de/~willhalm
Date: 25 Aug 1998 08:33:44
Message: <qqmvhnh47or.fsf@goldach.fmi.uni-konstanz.de>
"K. Tyler" <tyl### [at] pacbellnet> writes:
> This is a multi-part message in MIME format.
> --------------C4F75C83F17358093F274ECC
> Content-Type: text/plain; charset=us-ascii
> Content-Transfer-Encoding: 7bit
> > > there any UNIX (or other) people out there who can confirm/deny this
> > > rumor?
> > > -Nathan
> > nota single byte. The scene contains spheres, cylinders, bezier patches
> > and a plane. At least these features seem to work perfectly.
> I'm attaching a POV-Ray scene file that is a Pov twisting
> memory busting son of a gun. I've tried rendering it 4 times
> tonight and have had 4 different results memory and rendering
> wise.
> #1 It rendered to 99% and crashed not only Pov 3.01
> but also my windows 95 session.
> #2 Tried it on Pov 3.1b4. It parsed almost twice as fast but
> crashed as soon as it started to render. Had to reboot again.
> Windows warning about system resources to low to operate.
> #3 opened again in 3.01. Parsed up to the vista buffer stage
> and crashed. System again had to be rebooted to regain stability.
> #4 opened again in 3.01. Parsed and rendered to 84% then
> completely crashed the system. Total system freeze up.
After replacing "finish{Fin}" by "finish{Dull}" it rendered flawlessly on a
Sun, and purify didn't report any errors. AFAIK the generic unix version
corresponds to 3.01.
> I'd like to be able to tell you what the total memory usage of this
> file is but Pov doesn't report peak memory use until after it's finished
> rendering. Since I haven't gotten that far yet I just don't know.
Smallest Alloc:                 11 bytes   Largest:          1053704
Peak memory used:         87557991 bytes
> Please mention your system platform, onboard memory, and system speed.
Sun Enterprise 4000/5000 with 4 336 MHz SUNW,UltraSPARC-II CPUs (used only
1 CPU), 1024 MB RAM running SunOS 5.5.1
Date: 25 Aug 1998 12:32:51
Message: <35e2d90a.22906095@news.povray.org>
>I'd love it if a few people would try out this scene file on their
>respective systems and leave a post of your results or hardships.
>system speed.
>If enough people get differing results I'll send a bug/memory report
>to the POV-Ray team.
My results (640x480 no aa) with AMD K5 166, Asus TX97, 64MB Windows 95
are:
POV-Ray for Windows 3.02.watcom.win32 (Pentium optimized):
  Smallest Alloc: 27 bytes, Largest: 1053704
  Peak memory used: 111648519 bytes
  Time for parse: 30:40 minutes
  Time for trace  11:13 minutes
  Total Time:     41:53 minutes
POV-Ray for Windows 3.1.beta.5.watcom.win32 (Pentium II optimized):
  Smallest Alloc: 27 bytes, Largest: 1053720
  Peak memory used: 110058039 bytes
  Time for parse: 27:16 minutes
  Time for trace  10:39 minutes
  Total Time:     37:55 minutes
Bye,
Friedemann
Friedemann Schmidt
Fri### [at] Stonescom
Raytracing-Gallery: http://www.rz.fhtw-berlin.de/~s0049669/
Date: 25 Aug 1998 16:31:23
Message: <35e31101.37235319@news.povray.org>
>Can I presume from the statement Pentium optimized thatthese are unofficial
>compiles of POV-Ray ?
No, I get these informations from the "About" dialog of POV-Ray for
Windows... I think there's no unofficial compile of version 3.1 by
now, because the sources aren't still available.
Bye,
Friedemann
Friedemann Schmidt
