POV-Ray : Newsgroups : povray.programming : Creating a hemisphere with tori? Server Time
30 Sep 2024 04:18:16 EDT (-0400)
  Creating a hemisphere with tori? (Message 1 to 5 of 5)
Subject: Creating a hemisphere with tori?
Date: 20 Aug 1998 18:15:50
Message: <35DC9198.BDEF7983@home.com>
Hi there-
I'm trying to create a 'screen' for my povray bong using tori.
At the same time I'm trying learn how to use povrays programming
directives so I do'nt have to write so many lines of code.
I'm including the code I've already written so you can see what I'm
attempting to do.
/ Persistence of Vision Ray Tracer Scene Description File
// File:screen.pov
// Vers: 3.1
// Desc: screen created with tori
// Date: 8/20/98
// Auth: ArfGrafix
// ==== Standard POV-Ray Includes ====
#include "colors.inc"	// Standard Color definitions
#include "textures.inc"	// Standard Texture definitions
#include "metals.inc"
// Set a color of the background (sky)
background { White }
camera
  location  <0.0 , 2.0 ,-5.0>
  look_at   <0.0 , 0.0 , 0.0>
// create a regular point light source
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-20, 40, -20>
#declare b_ring =
  torus { 2, .0625 pigment { P_Brass3 } finish { F_MetalC }  }
 object { b_ring scale .9 translate .1*y }
 object { b_ring scale .8 translate .2*y }
 object { b_ring scale .7 translate .3*y }
 object { b_ring scale .6 translate .4*y }
 object { b_ring scale .5 translate .5*y }
 object { b_ring scale .4 translate .6*y }
 object { b_ring scale .3 translate .7*y }
 object { b_ring scale .2 translate .8*y }
 object { b_ring scale .1 translate .9*y }
I wrote this piece of code and soon found out that this creates a
conical series of tori...I tried making a while loop to do this, but was
flummoxed by the task of having the while do two different operations.
What I want is series of tori that form a hemisphere rather than a
cone..that is each torus is a latitudinal strip that trace out a
hemisphere.
Thanks in advance for any helpful input that anyone may have.
Best regards,
Ron Hicks
sig### [at] hotmailcom
http://www.geocities.com/SoHo/1006
Subject: Re: Creating a hemisphere with tori?
Date: 20 Aug 1998 20:59:22
Message: <35DCB857.22A@merlin.net.au>
Daniel Sullivan wrote:
> Hi there-
> attempting to do.
> // File:screen.pov
> // Vers: 3.1
> // Date: 8/20/98
> // Auth: ArfGrafix
> camera
> light_source
> #declare b_ring =
> hemisphere.
> Best regards,
> Ron Hicks
First point, do you want the thickness of the ring to decrease as the
height increases? This is what scaling the object is doing. If not then
try
union
  #declare a = .1 #while(a < 1)
  torus { cos(asin(a)),.04 translate y*a }
    #declare a = a+.1 #end
  finish { F_MetalC }
Note I made the minor radius a bit smaller since it's not being scaled.
On a circle drawn on the XY plane, X is proportional to cos(a) and Y is
proportional to sin(a) so you can derive the angle by asin(a), then get
the X (or major radius in this case) by cos(asin(a)).
If you do want the same as you had but a hemispherical version try
	object{b_ring scale cos(asin(a)) translate y*a }
Hope this helps.
Cheers, PoD.
Date: 22 Aug 1998 08:31:19
Message: <01bdcdc0$88e70ba0$40563fc3@hitex_mo.hitex.de>
PoD <pod### [at] merlinnetau> schrieb im Beitrag <35D### [at] merlinnetau>...
> > Hi there-
> > attempting to do.
> > [SNIP]
> [SNIP]
Wouldn't:
	#declare a = 0.1
	#while( a < 1 )
		object{ b_ring scale 1 - a translate y * a }
		#declare a = a + 0.1
be a lot easier to read (and understand)?
Best regards,
 _ __                      _    ,   _ _ _
' )  )     /         _/_  ' )  /   ' ) ) )
 /--' ____/___/> __  /     /--/     / / / __,_  __  o _   ______
/  \_(_) /_) (__/ (_<__   /  ( o   / ' (_(_) (_/ (_<_/_)_(_) / <_
Robert H. Morrison                      Tel:   +49 721 9628 167
Software Development, Basis Team        FAX:   +49 721 9628 261
Hitex-Systementwicklung GmbH            Email: RMorrison@hitex.de
Date: 22 Aug 1998 19:42:54
Message: <35DF496D.714C@merlin.net.au>
[snip]
> Wouldn't:
>         #declare a = 0.1
>         #while( a < 1 )
>         #end
> Best regards,
>  _ __                      _    ,   _ _ _
The point is to make a hemisphere of tori rather than a cone.
Cheers, PoD.
Date: 23 Aug 1998 02:17:47
Message: <35DFA570.D40A1022@home.com>
> > Hi there-
> > attempting to do.
> > // File:screen.pov
> > // Vers: 3.1
> > // Date: 8/20/98
> > // Auth: ArfGrafix
> > camera
> > light_source
> > #declare b_ring =
> > hemisphere.
> > Best regards,
> > Ron Hicks
> try
> union
>   finish { F_MetalC }
> Hope this helps.
> Cheers, PoD.
Pod-
many thanks for your help with the routine.....after a little fiddling
with what you had suggested I came up with a with a real nice screen for
my povray bong.
after I had posted the query to the newsgroup I felt adventurous and
tried to formulate my own routine for creating the hemisphere after
scratching the problem out with pencil and paper and here's what I came
up with...but with strange results.
You can find my improved povray bong in the povray immages group:)
camera
  location  <0.0 , 2 ,-5>
light_source
#declare m =2;
   #declare c = 0;
        #while (c < 90)
        #declare m = m*cos(c)
            torus { m, m/16 translate sin(c)*y pigment { Red } }
         #declare c = c+10;
What am I missing here?
Many thanks in advance.
Best Regards,
Ron Hicks
