POV-Ray : Newsgroups : povray.programming : Slope dependent textures Server Time
13 Jul 2025 01:00:37 EDT (-0400)
  Slope dependent textures (Message 1 to 10 of 11)
Subject: Slope dependent textures
Date: 6 Apr 1998 12:14:23
Message: <3528FF5F.700B@pecos.n.o-s.p.a.m.de>
Hi pov friends!
As discussed in povray.binaries.images already,
I have patched POV 3.02 for slope dependent textures.
The new keyword slope is used in a similar way as
eg 'gradient'. It takes a vector as its parameter.
It returns values between 0.0 and 1.0, depending
on the angle between the local surface normal and
the slope parameter vector. 0.0 means antiparallel,
0.5 means perpendicular, 1.0 is parallel.
Thus, with 'slope y' it is quite easy to give your
objects a snow (or sands or whatever) covered outfit.
If you want to give it a try: the patch is available
at ftp://user.pecos.de/pub/povray. It contains a readme
and two patch files (in unified diff format). One is for
plain POV 3.02 source, the other one is for 3.02 source that
contains R. Suzuki's iso-surface patch (beta-18).
As usual, this is an unofficial patch.
Enjoy.
-Hans-
Remove n.o-s.p.a.m. to obtain my real address.
In seeking the unattainable,
simplicity only gets in the way.
-- ACM SIGPLAN Sept. 1982
Subject: Re: Slope dependent textures
Date: 6 Apr 1998 14:23:23
Message: <35291bfc.19006359@10.0.2.33>
On Mon, 06 Apr 1998 18:14:23 +0200, Hans-Detlev Fink
Very nice.  Mind if I add it to my superpatch?  I'll give proper
credit when I finally make the superpatch available.
Also, in your Readme file, I see:
>  Example: slope y
>This is what everyone associates with slopes in
>landscapes. For all surface elements that are horizontal
>slope returns 1.0. All vertical parts return 0.5 and all
>'anti-horizontal' surfaces (pointing downwards) return
>0.0.
Doesn't a slope of 1.0 correspond to a "vertical" surface, while 0.5
corresponds to "horizontal?"
Date: 6 Apr 1998 19:16:44
Message: <3529625B.E946B266@pecos.n.o-s.p.a.m.de>
Fine.  Please contact me before final release of yourpatch. Just in case
I have some bugfixes to contribute.
I would be really happy if as many people as possible
tested the patch. I suspect I was far from all those
'pathological' scenes in my tests.
> >  Example: slope y
> >0.0.
No.  Well, depends on vertical with respect to what. You are
right if you mean a surface that is perpendicular to y.
I meant vertical in the everday way, ie a surface that is parallel
to y (like a wall etc.).
For this definition of vertical surfaces the surface normal is
in the x-z-plane and thus perpendicular to y. The 'dot' product
of the surface normal and y is therefore 0, which is eventually
translated to 0.5. Similarly a horizontal surface's normal points
in y direction. The product is 1.0, which is translated to 1.0.
Anti-horizontal yields a product of -1.0 which is transformed
to 0.0. (Have a look at slope() at the end of pattern.c.)
I was not sure whether or not I should map the values this way.
Originally I began with 1.0 for horizontal and 0.0 for vertical, all
'negative' surfaces were mapped to 0.0.  At the end I felt that
this was an unnecessary restriction (imagine rocks or asteroids
whose lower surface shall have a specific texture). So I did it
as I did. (A more intuitive way would be a mapping between
-1.0 and +1.0, but that would break the general structure of
maps in povray.)
-Hans-
Date: 7 Apr 1998 09:18:19
Message: <352b26d4.479269@10.0.2.33>
On Tue, 07 Apr 1998 01:16:44 +0200, Hans-Detlev Fink <hdf### [at] pecosde>
Doh! I even looked at the code you mention, but I messed up on that
one.  The _normal_ is vertical for slopes of 0 or 1.  Oops.
BTW, one fix for the bug you mention in the readme file is to use a
symmetrical color map.  This works in cases where you don't draw a
distinction between horizontal and "anti-horizontal."  In other cases,
such as the pyramid with sand on one surface, this won't work.
Date: 8 Apr 1998 01:02:05
Message: <6gf0in$i2j$1@oz.aussie.org>
Ronald, do you have a mailing list for your super patch?
- Grim
Date: 8 Apr 1998 09:32:04
Message: <352c7bab.1894624@10.0.2.33>
On Wed, 8 Apr 1998 00:02:05 -0500, "GrimDude" <gri### [at] swbellnet>
Not yet.  Apparently I should, since that's two people today who've
expressed an interest.  If you'd like, I'll start keeping a list and
add you to it, but I will post any updates on the status of the
superpatch here just as soon as anything happens.  (See my other post
from today for why nothing has happened yet.)
Date: 8 Apr 1998 12:58:34
Message: <6ggahu$jq0$1@oz.aussie.org>
Well, hey man, add me to your list (just in case I should miss your post
here). :)
- Grim
Date: 8 Apr 1998 14:15:39
Message: <6ggbic$jr8$1@oz.aussie.org>
I believe it was Ronald who suggested I do a "repository" for all the custom
patches, and thus, I shall!
If ANYONE has a patch they want to put on a website, I'll give it a home. =)
Just e-mail me, and we can work out something.... :)
Twyst================================
EFnet and NewNet #povray Channel Operator
Website: http://twyst.home.ml.org
E-Mail: twy### [at] v-wavecom
Date: 8 Apr 1998 15:47:59
Message: <352bd1e0.23963097@10.0.2.33>
On Wed, 8 Apr 1998 11:15:39 -0700, "Twyst" <sir### [at] hotmailcom>
Not necessarily a repository, but at least a directory.  The only
directory I've found to date still lists a bunch of old 2.0 patches
that don't work or are unnecessary for 3.0, and doesn't list a lot of
new ones.
Here's my current list of "patches I know about", copied from my
Netscape Bookmark file.  The patch we're discussing in this thread
hasn't made it in yet; nor have the ones on ftp.povray.org (or
ftp.cdrom.com/pub/povray), mainly because they're mostly for 2.0.
Some are missing good documentation, which is why that will be the
most time-consuming part of my superpatch.
http://www.newcolor.com/darenw/dswpov/dswpov.html
Dispersion and Other Modifications to POV-Ray
http://www.newcolor.com/darenw/dswpov/unlimit.html
Unlimited Light mod for POVRay
  (Sources for the previous two at
  http://www.newcolor.com/darenw/dswpov/stash/
  but it wasn't ready for prime time last time I checked.  Has anyone
  heard from DSW recently?)
http://www.informatik.uni-bremen.de/~vader/pss/pss.html
POV-Ray with Sphere Sweeps
http://www.public.usit.net/rsuzuki/e/povray/iso/index.html
POV-Ray 3.0 isosurface pactch
ftp://atrey.karlin.mff.cuni.cz/pub/local/0rfelyus/povray-3.02/
Daniel Skarda - Rational Bezier Surface patch
http://pandora.inf.uni-jena.de/noo/povsplines.html
POV-RaySP - POV-Ray with Splines
http://member.aol.com/kochinc/povray/cjkpov.html
Rendering Double-Byte TTF Characters in POV-Ray v3.0
(Already included in isosurface patch.)
http://www2.fwi.com/~parkerr/traces.html
Object Bounds patch for POV-Ray
Date: 8 Apr 1998 23:20:28
Message: <6ghbfr$l4l$1@oz.aussie.org>
Ronald L. Parker wrote in message <352bd1e0.23963097@10.0.2.33>...
custom
>new ones.
Great..
Ok. the question here is: Should I write the authors, and ask if I can offer
them on my site? Or just put a link?
hehe.. Either way, I've got to re-design my site. Man. The things you do for
Pov-Ray. =P
On another note: ( insert shameless site plug here )
I will soon be putting some reviews on my site, just as soon as I can get a
group of Pov users who are willing to rate apps.. I would *like* to review
ALL major apps on all platforms, as well as have a list of the top 15
indispensible .inc files... but I know that my opinion may differ from
someone elses, which is why I'd like to get at least 3 people's input on
each program.
