POV-Ray : Newsgroups : povray.pov4.discussion.general : 2D-Scriplanguage-extension for textures Server Time
19 May 2024 22:57:24 EDT (-0400)
  2D-Scriplanguage-extension for textures (Message 1 to 8 of 8)
Subject: 2D-Scriplanguage-extension for textures
Date: 27 Apr 2012 20:25:00
Message: <web.4f9b37f57cf8ee01a3bfeb720@news.povray.org>
How complicate is it to enhance Pov-Ray to do 2D by script to be used for
textures?
Best Rgds,
Holger :)
Subject: Re: 2D-Scriplanguage-extension for textures
Date: 28 Apr 2012 04:36:25
Message: <4f9bac09@news.povray.org>
> textures?
  I think you'll have to be a bit more specific.
Date: 13 May 2012 15:30:15
Message: <XnsA052DAC35E1B6seed7@news.povray.org>
> for textures?
SVG would be nice to have,
ingo
Date: 14 May 2012 06:24:10
Message: <4fb0dd4a@news.povray.org>
Am 13.05.2012 21:30, schrieb ingo:
>> for textures?
... and probably complicated to implement. After all, the normal use
case for rendering SVG is to rasterize the image, i.e. convert it to a
classic bitmap image. Even for /that/ it appears to be difficult to find
a suitable free platform-independent library. And it doesn't give you
any significant benefit over converting the SVG to a bitmap format using
some external tool. In order to take full advantage of SVG, we'd need a
library capable of probing random points of the image /without/
converting it to a bitmap first. I doubt that any such library does
exist at all, let alone a free platform-independent one.
And no, I'm pretty sure the POV-Ray dev team will not put any effort in
writing such a library themselves, due to the complexity of the format.
Then again, if anyone not yet involved in POV-Ray development would be
willing to pick up that glove, they might find themselves welcome.
Date: 14 May 2012 22:00:00
Message: <web.4fb1b83b3c38dca09726a3c10@news.povray.org>
[Snip some good points]
If someone really wanted this, they could use XSLT to transmorgrify SVG elements
into corresponding POV-Ray objects (with some user-defined thickness)...
....Of course, "Now they have two problems."
Date: 15 May 2012 09:03:06
Message: <4fb2540a$1@news.povray.org>
Am 15.05.2012 03:58, schrieb waggy:
> .....Of course, "Now they have two problems."
That's fine with me, as long as nobody suggests to implement an XSLT
processor as part of POV-Ray... >_<
Date: 15 May 2012 15:47:04
Message: <XnsA054DD9C297C6seed7@news.povray.org>
just interested, would you need points or a rendersize dependent bounding
box that can be rasterized and then mapped? Like zooming in on the SVG?
ingo
Date: 15 May 2012 18:55:29
Message: <4fb2dee1$1@news.povray.org>
Am 15.05.2012 21:47, schrieb ingo:
I'm not sure whether I understand your question.
In a normal scene it could possibly suffice to rasterize the SVG to a
heuristically determined resolution, e.g. proportional to render image
resolution divided by distance to the camera. But there are various
scenarios where such a heuristic would break down.
There might be ways to employ bitmaps generated from the SVG to improve
speed for large, "flat" areas, but in the end it will be necessary to
have a library that can tell the exact color for an arbitrary point in
2D space, as long as you want any benefit over using an external
SVG-to-bitmap conversion tool.
POV-Ray renders objects by shooting individual rays, and computing the
object surface properties at the ray-object intersection point; at that
time, POV-Ray has no reliable knowledge of how close the "neighbor" rays
will hit, and therefore no way of telling what spatial precision it will
need for looking up the surface properties.
It should theoretically be possible to make POV-Ray aware of the spatial
precision of individual rays, but it would require solving not only an
object's surface function (which describes the object's shape) and its
derivative (which describes the surface orientation aka normal), but
also its second derivative (which describes the surface curvature). This
would have to be implemented for each and every geometric primitive, and
might be far from trivial for some of them.
