POV-Ray : Newsgroups : povray.pov4.discussion.general : Run external code from Server Time
17 Dec 2025 22:41:55 EST (-0500)
  Run external code from (Message 1 to 8 of 8)
Subject: Run external code from
Date: 18 Apr 2010 15:50:01
Message: <web.4bcb6128e027238bdec81f370@news.povray.org>
ok it's possible to run external code before and/or after the rendering in
PovRay.
What if having a syntax to run it from inside the script like a macro
#declare Result=external_code_lua("Path/Name",Arguments)
#declare Result=external_code_python("Path/Name",Arguments)
#declare Result=external_code_php("Path/Name",Arguments)
#declare Result=external_code_perl("Path/Name",Arguments)
#declare Result=external_code_java("Path/Name",Arguments)
#declare Result=external_code_bin("Path/Name",Arguments) (using stdout as
return-value)
- to run an external code, then convert it's information into CSV
- calculate big amounts of values faster, like convert PCM(PackedMesh) back into
mech or mesh2
- making SDS externally and much faster (a thing, that can become _very_ slow in
PovRay)
- converting NURBS into Mesh or Patches
- having excess to hardware, not available from Pov-script
- making Pov-script interactive (like making a 80s-like adventure-game with
PovRay) (ok, for this PovRay would also need to have the option to run in an
infinite loop then, or you start PovRay with your script or .ini-file as
post-command from PovRay... I never tried this!)
Think of it: depending on the language using, you can make PovRay
object-orientated!
From my personal taste, I would like to use Lua. It's designed to be used inside
other programs, or scripts. It's object-orientated, fast, free, opencource (I
think its MIT-License) and small.
If it's to complicate to program this, still a "bin"-call would be cool enough
to make extreme nice things.
Best regards,
Holger
Download 'rendering.jpg' (26 KB)
Preview of image 'rendering.jpg'
Subject: Re: Run external code from
Date: 18 Apr 2010 16:01:00
Message: <4bcb64fc$1@news.povray.org>
Am 18.04.2010 21:44, schrieb H. Karsten:
> PovRay.
> return-value)
> object-orientated!
Would there still be a big benefit in that, presuming the POV-Ray 4 SDL
itself would be object-oriented and as fast as Lua or some such in the
first place (which I consider a prime goal for POV-Ray 4)?
Date: 19 Apr 2010 18:10:00
Message: <web.4bccd472417b29d3dec81f370@news.povray.org>
Having this as the primary priority is definitely cool.
Maybe, it's a good thing to compile PovCode before rendering.
But I still say: keep it tiny and fast _and_ open for everything.
So maybe the people don't need to rewrite there code, already exist in another
language. Or you need to have some functions for some special things, you would
never ever put into a scrip-language, designed for 3d-graphics.
You never know what happens ...
Date: 20 Apr 2010 03:20:03
Message: <4bcd55a3$1@news.povray.org>
Am 20.04.2010 00:09, schrieb H. Karsten:
The problem with these design goals is that they tend to be mutually
exclusive. Especially being open for /everything/ is bound to add
considerable overhead.
Date: 20 Apr 2010 14:45:01
Message: <web.4bcdf549417b29d3dec81f370@news.povray.org>
Well ok - but if you open it for /something/, you already can use the next level
to go deepen into the problem and it's solve.
Like using some opening (if necessary) from inside the next language (like
hardware access, assembler connection, or some interactive windows for the user)
So maybe a bin-connection from inside the code is enough. The coder can do some
additional connection from the executable by himself.
Date: 20 Apr 2010 15:19:51
Message: <4bcdfe57$1@news.povray.org>
Am 20.04.2010 20:41, schrieb H. Karsten:
Uh-huh... I'm not quite sure what this has to do with rendering (except
maybe for the "assembler connection")...
Can't be too difficult, huh?
May I put you on the list of volunteer developers for POV-Ray 4? :-P
Date: 26 Jul 2010 11:37:09
Message: <4c4daba5$1@news.povray.org>
You could try and write a parser that reads whatever language you want
as input and outputs POV SDL to see how easy it is. I've personally
written a Lua parser, and despite all the work I put into it there are
still probably situations where it chokes and fails!
http://isometricland.com
Date: 26 Jul 2010 11:40:47
Message: <4c4dac7f$1@news.povray.org>
Oops, I need to check the original post dates more carefully. This
thread is pretty dead.
