POV-Ray : Newsgroups : povray.pov4.discussion.general : Support of NURBS-Surfaces Server Time
1 Jun 2024 11:21:19 EDT (-0400)
  Support of NURBS-Surfaces (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Support of NURBS-Surfaces
Date: 17 Nov 2009 09:57:31
Message: <4b02b9db$1@news.povray.org>
> Being able to adjust the detail level without having to re-export the
> mesh?
I find it easier to do that in the modeller, there you can interactively see
the size of the triangles and adjust the detail until it looks good without
too much overkill.  Of course if you radically change the viewpoint or
something you might need to re-export, but overall I find that faster than
tweaking with parameters in POV (which is usually quite a slow process).
> I'm also not sure whether converting to triangles is an absolute
> necessity.
Being able to render the patches directly without triangulating would be
cool!  I guess you "just" need a ray-patch intersection formula - does such
a thing exist?  Or use some kind of sampling method like media to find the
surface?  I have no idea if that will be any faster than splitting up into
pixel sized triangles.
Date: 17 Nov 2009 10:12:01
Message: <op.u3joiay27bxctx@e6600>
> such a thing exist?
Yes, such a thing exists, but the math is a bit complicated, and
performance is likely to be underwhelming.
http://www.google.com/search?q=nurbs+ray+intersection
FE
Date: 17 Nov 2009 22:15:01
Message: <web.4b0366101a8c6309da6353d60@news.povray.org>
The Pixar Renderman is rendering NURBS and Patches without triangulation in
before.
Its very fast, saves times and space.
Holger
Date: 17 Nov 2009 22:20:01
Message: <web.4b0366e51a8c6309da6353d60@news.povray.org>
Chambers <Ben### [at] gmailcom> wrote:
> It's easy enough to write a macro to handle streams of patches for you,
> if you already have the data. The last time I wrote one, I think I
> finished it in under an hour.
> The problem, of course, is getting the data in the first place.
> Creating NURBS via text editors is not easy.
> ...Chambers
Then, it shouldn't be a problem to compile such a feature into PovRay.
I don't know, how to write such a Macro, but rendering a NURBS-surface in
PovRay, without any problems for the user would still be a cool thing.
Date: 17 Nov 2009 23:24:46
Message: <4b03770e@news.povray.org>
>> necessity.
> such a thing exist?
You actually need a ray-patch intersection /algorithm/. Which may be
based on a formula of course.
You also need an algorithm to compute a bounding box.
> find the surface?
That would probably be difficult. It's hard to tell which side of the
patch you're on.
I guess it'll probably boil down to something like computing a polynom,
and then solving it for zero.
> splitting up into pixel sized triangles.
I have no idea. At least it'll be more memory-efficient.
Date: 17 Nov 2009 23:37:42
Message: <4b037a16$1@news.povray.org>
>> be cool!  I guess you "just" need a ray-patch intersection formula -
>> does such a thing exist?
The very first entry /looks/ promising though.
Date: 19 Nov 2009 00:17:14
Message: <4b04d4da$1@news.povray.org>
> such a thing exist?  Or use some kind of sampling method like media to
> find the surface?  I have no idea if that will be any faster than
Sure, they exist.  I used to expand functions like that by hand for fun
(yes, I was weird... actually, I'm *still* weird :) ).  I think a
bicubic patch filled most of an 8.5x11 page if you wrote small ;)
...Chambers
Date: 24 Nov 2009 13:40:00
Message: <web.4b0c280b1a8c6309ccf67d800@news.povray.org>
> before.
> Holger
https://renderman.pixar.com/products/whats_renderman/2.html
On the contrary, Pixar turns all surfaces into triangles based on pixel space.
This is how it is able to render displacement so well
Date: 16 Dec 2009 08:30:01
Message: <web.4b28df621a8c63097ccd22920@news.povray.org>
> > ...Chambers
I once made a lot of NURBS macros for POV-Ray.
Here's an image made with some of them:
http://home.online.no/~t-o-k/POV-Ray/NURBS-Bivariate_Mesh.jpg
Some more of my NURBS images can be found here:
http://home.online.no/~t-o-k/POV-Ray_Images/
I guess that the average user would find that using using NURBS (and get full
control over them) is somewhat difficult, especially with a textual user
interface.
I.e.: They would have to learn about about different types of knot vectors and
about the effects of changing the weights for the control points.
With at text interface it may also be a lot of work to get the control points in
the control mesh positioned so that the NURBS surface gets the desired shape.
Tor Olav
http://subcube.com
Date: 16 Dec 2009 09:25:00
Message: <web.4b28ed3c1a8c63097ccd22920@news.povray.org>
> >> necessity.
> > such a thing exist?
A good start for a bounding box for a NURBS surface would be a bounding box that
contains all the points in its control grid
Tor Olav
http://subcube.com
