POV-Ray : Newsgroups : povray.pov4.discussion.general : Feature Request - Texture Overlay Server Time
4 Mar 2026 22:17:37 EST (-0500)
  Feature Request - Texture Overlay (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Feature Request - Texture Overlay
Date: 25 Jan 2008 04:05:17
Message: <4799a64d$1@news.povray.org>
Kyle wrote:
> This simplistic example does not demonstrate how helpful this functionality would
be.  A better
> example is a recent scene that I was working on in which I was building a brick
road.  I defined a
> section of road as a union of 36x100 randomly textured bricks.  I then placed the
sections
> end-to-end to form the complete road.  I wanted to have lines on the road too, but
wanted some
> waviness to the lines for more realism.  Overlaying a texture on the entire road
would be the
> simplest method, providing there was a method to do so.
In this example, you could actually place all the bricks in a union and
give them a single texture block.
...Ben Chambers
www.pacificwebguy.com
Date: 25 Jan 2008 05:29:54
Message: <4799ba22$1@news.povray.org>
> Functionality that I think would be helpful is a method to overlay a
> previously textured object with
> a new texture.  Perhaps this could be specified with an "overlay" keyword,
> such as this:
> object {
>  o_PreviouslyTexturedObject
>  texture {
>    pigment { p_PartiallyClearPigment }
>    overlay
Uh - you can already do this can't you? just take out the "overlay" keyword
and it works!
Date: 25 Jan 2008 07:37:31
Message: <4799d80b@news.povray.org>
> and it works!
  No, because a later texture definition will not modify an existing one.
Date: 25 Jan 2008 08:10:01
Message: <web.4799def8e1857b77c150d4c10@news.povray.org>
Chambers <ben### [at] pacificwebguycom> wrote:
be.  A better
road.  I defined a
sections
wanted some
would be the
> ...Ben Chambers
I think what he wants to achieve, is to have the subtextures for each brick
different by some degree and applied to each brick individually.
There are some ways this could be achieved with a single texture block, but they
would tend to be very complex, a texture overlay would be a lot simpler.
-tgq
Date: 25 Jan 2008 08:14:21
Message: <k1njp3le8kfdn8cm0hmab4g969fc7aq1n8@4ax.com>
On Fri, 25 Jan 2008 01:05:15 -0800, Chambers <ben### [at] pacificwebguycom> wrote:
be.  A better
road.  I defined a
sections
wanted some
would be the
Yes, it would work.  The problem was that the memory used by a 2000x37 brick road
exceeded the memory I had available and drive thrashing ensued.  Breaking the road
down into sections resolved the
memory issue, but then I couldn't texture the road as one object.  Here's a link to a
thread where I posted an example and the discussion led to a solution, although it
used more memory than an
overlaid texture would...
http://news.povray.org/povray.general/thread/%3Chp0ro31f9m1dr7spccdp4g3j0hj5fvhdh0%404ax.com%3E/
There are other examples I can think of where overlaying a texture would be applicable
as well.  What if you want to add a texture layer to a predefined, pre-textured mesh
object, perhaps one that's
UV mapped using image maps?  That'd be kind of complex, if not impossible, without
being able to overlay the existing texture.
Perhaps you have a complex object that you've built and textured, but it looks to
clean and you want to add a little "dirt".  You can go back and use layered textures
on each piece of the object, or
you can overlay one dirt texture over the entire object.  Imagine trying to transform
the dirt texture on each piece of a complex object to have any patterns in the dirt
line up properly between
pieces of the object.  An overlaid texture would be much simpler.
Date: 25 Jan 2008 08:26:46
Message: <6oojp3lpnpo4po67jf5e19dl842v4c5oqi@4ax.com>
>> such as this:
>> object {
>>  texture {
>>    overlay
>and it works!
With basic objects, yes, but not with complex objects.
Try this...
#declare p_PartiallyClearPigment =
    granite
    color_map {
      [0 rgbf 1]
      [1 rgb <1,0,0>]
#declare o_PreviouslyTexturedObject =
  union {
    sphere {
      x/2, 0.5
      pigment { rgb <0,1,0> }
    sphere {
      -x/2, 0.5
      pigment { rgb <0,0,1> }
object {
    //overlay
Date: 25 Jan 2008 08:30:23
Message: <11pjp353c5oq1alqao3qlu6oenv6hna2jm@4ax.com>
>> and it works!
Scott is partially right.  This works...
    granite
    color_map {
      [0 rgbf 1]
      [1 rgb <1,0,0>]
  sphere {
    x/2, 0.5
object {
    //overlay
... but it will not work with more complex objects.
Date: 28 Jan 2008 04:10:23
Message: <479d9bff$1@news.povray.org>
>> keyword
>> and it works!
Didn't he want to add another texture over the top, not modify the existing
one(s)?
Anyway, definitely weird that it only works for single objects, should be
fixed to have the same behaviour with unions/merges etc.
Date: 28 Jan 2008 08:53:31
Message: <pgnrp3hev23ng12j2u8fuqijr41gerk38h@4ax.com>
>one(s)?
Yes, that's it exactly.
Date: 28 Jan 2008 10:15:43
Message: <479df19f$1@news.povray.org>
>>existing
>>one(s)?
Well in that case the request seems clear:
Currently POV allows you to add another texture to (perhaps partially) cover
an already-defined object, only if the already-defined object is a single
primitive.
The request is to extend this feature so that it works with all
already-defined objects, not just those that only consist of a single
primitive.
Seems like a pretty fair request to me - actually I was surprised this
didn't work already.
