POV-Ray : Newsgroups : povray.pov4.discussion.general : Render changes. yuqk / v4. Option re-work status. Server Time
16 Jan 2026 07:17:27 EST (-0500)
  Render changes. yuqk / v4. Option re-work status. (Message 1 to 2 of 2)
Subject: Render changes. yuqk / v4. Option re-work status.
Date: 8 Jun 2025 10:43:23
Message: <6845a18b$1@news.povray.org>
The current render related options:
+-rp render_pattern
+-rs render_block_step
+-bs render_block_size
+-c  continue_trace
+-cc create_continue_trace_log
+-ec end_column    (pct and integer specs)
+-er end_row       (pct and integer specs)
+-sc start_column  (pct and integer specs)
+-sr start_row     (pct and integer specs)
      (Single, hard coded color conversion to gry)
become:
+-r     render                 on|off               NEW
+-rp    render_pattern         integer value only
+-rbstp render_block_step      integer value only
+-rbsz  render_block_size      integer value only
+-rc    render_continue        on|off
+-rcl   render_continue_log    on|off
+-rec   render_end_column      integer on|off plus value
+-rer   render_end_row         integer on|off plus value
+-rsc   render_start_column    integer on|off plus value
+-rsr   render_start_row       integer on|off plus value
+-rgm_  render_gry_method      string  value only  NEW
           (ci111,ci240,ci601,ci709,ci2020)
Aims / thinking :
- Mostly renaming.
- Adding flag indicating whether or not to run the render stage/module.
- Removing the percentage specifications for the start/end/col/row
options. I "think" the yuqk fork fixed the last of the bugs due trying
to accommodate the percentages and numbers on the same flag, but the
code remains ugly. If it's decided later this feature essential, another
set of flags which specifically supports it should be added.
- Biggest planned change is making the render/tracing color conversions
to grey select-able at render time. Including here perhaps a development
mode hard coding a dummy value - or, maybe, using the green channel
directly. Maybe look too, at something better than our current grey
weighted 'conserve_energy', for example.
- Off on the horizon is perhaps moving away from / extending or changing
the render block mechanism. Thinking about optimizations for the
'locality of references' and maybe a mode which skips blocks if they
exceeds some multiple of all the average time used to render blocks thus
far. I have in mind too multiple camera driven over-sampling methods
which won't work with the current render blocks mechanism. Dreaming...
Code wise, the parsing code itself for these is only partly done.
Bill P.
Subject: Re: Render changes. yuqk / v4. Option re-work status.
Date: 8 Jun 2025 11:00:31
Message: <6845a58f$1@news.povray.org>
On 6/8/25 10:43, William F Pokorny wrote:
> +-r     render
on|off               NEW
Ugh. That line should have read:
  +-render render                 on|off               NEW
I think for the moment, I'll stop my status updates here. I'm now on the
edge of the work I have implemented, parsing code, wise.
Bill P.
