POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 updates to leopard pattern. (yuqk R17 v0.6.11.0) Server Time
16 Jan 2026 05:29:43 EST (-0500)
  Suggest v4.0 updates to leopard pattern. (yuqk R17 v0.6.11.0) (Message 1 to 1 of 1)
Subject: Suggest v4.0 updates to leopard pattern. (yuqk R17 v0.6.11.0)
Date: 13 Nov 2024 18:08:16
Message: <67353160@news.povray.org>
In a manner similar to recent changes to the brick pattern, the leopard
pattern was re-written in yuqk to support an 'ip_form' keyword for more
control over how the pattern is generated.
Where one or two vector components are zero, the return values are more
reliably in the 0 to 1 range (The pattern still squares internally so
the value change is not linear).
The pattern's behavior is identical if the ip_form vector is left at the
default of <1,1,1>.
In the attached image using the leopard pattern on a squished sphere
(Go, go-ishi like shape).
Upper left uses the traditional pattern - which takes on different looks
depending upon where in the pattern the surface exists.
Upper right uses 'ip_form <1,1,0>'.
Lower left uses 'ip_form <1,4,0>'.
Lower right uses 'ip_form <pi,0,tau>'.
Bill P.
Download 'leopardupdtstory.png' (205 KB)
Preview of image 'leopardupdtstory.png'
