POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 read only identifiers. (yuqk R15 v0.6.9.0) Server Time
12 Nov 2026 16:44:14 EST (-0500)
  Suggest v4.0 read only identifiers. (yuqk R15 v0.6.9.0) (Message 1 to 25 of 25)
Subject: Suggest v4.0 read only identifiers. (yuqk R15 v0.6.9.0)
Date: 27 Jun 2024 11:44:27
Message: <667d88db$1@news.povray.org>
Release R15 of the yuqk fork has an implementation supporting constant
identifiers / macro parameters. They are indicated by using a leading
'_' character in the name.
Aside: I have hopes this mechanism a step toward enabling the safe
passing of function pointers into yuqk's inbuilt functions.
Attached a first pass at a little documentation for the feature.
Bill P.
Download 'underscorereadonlyidentifiers.txt' (3 KB)
Subject: Re: Suggest v4.0 read only identifiers. (yuqk R15 v0.6.9.0)
Date: 27 Jun 2024 12:05:00
Message: <web.667d8d8f4bc5dc757b170db125979125@news.povray.org>
> Bill P.
Very nice - I hope that works out the way you/we/everyone would like.
"Parse Error:
Attempt to #undef a constant identifier.
The identifier is:
    '_V99'
Due the leading '_' the existing identifier can only be read.
Fatal error in parser: Cannot parse input."
Is that a scene-wide global thing?
Due to some need to actually undefine or redefine a variable, maybe the leading
underscore could be a safeguard, rather than a complete lockout.
Maybe have some mechanism by which you can do the equivalent of su in a shell to
override the protections set in place to prevent casual/inadvertent overwriting.
Only saying this because it might make some things pretty awkward to code from
scratch / covert from legacy scenes into yuqk.
I dunno - maybe doing scene development you might want to have the safeguard in
place for the main scene, but during experimentation you want to turn off the
protection, but not scene-wide, only in the little test block of code that
you're fiddling with.
Just a thought.
Date: 27 Jun 2024 12:50:00
Message: <web.667d975d4bc5dc7517bac71e8ffb8ce3@news.povray.org>
There are quite a lot of include files out there that use a starting underscore
to prevent name space collisions. Many of these variables are also variable and
not 'static/constant'. Would that break scene's and includes?
(Would, for example a '#let' keyword for immutables be an option, or is that an
awful lot more work.)
ingo
Date: 27 Jun 2024 13:30:00
Message: <web.667da1134bc5dc75c7a7971d6cde94f1@news.povray.org>
hi,
agree with ingo, a keyword would be "cleaner".  we already can write:
  #macro foo(optional a)  ...  #end
suggest a 'const' or such ?  ie
  #macro foo(a, const b, optional c)  ...  #end
regards, jr.
Date: 27 Jun 2024 18:47:55
Message: <667dec1b$1@news.povray.org>
I also agree with Ingo: a keyword or directive would be better, such as:
  #const MagicNumber = 12345;
I'm thinking a keyword modifier would be more flexible than a directive,
for example:
  #declare const GlobalVal = 12345;
  #local const LocalVal = 54321;
Date: 27 Jun 2024 19:25:00
Message: <web.667df4b64bc5dc751f9dae3025979125@news.povray.org>
> for example:
Hmmm.   Yes, but maybe no?
Why not just have another separate type of declaration?
#declare
#local
#constant
We've also discussed
#persistent
as well as PRAGMA
So maybe #constant can ONLY be changed by specifically using another #constant
directive.
I dunno - I'm not really a computer language person, but the pro's and cons of
each approach ought to be hashed out with an eye towards Pov-Ray 4.0
- BW
Date: 28 Jun 2024 01:15:00
Message: <web.667e468a4bc5dc7517bac71e8ffb8ce3@news.povray.org>
#macro Add(_immuInt, otherInt)
#declare Res = Add(99,1)
#declare _immu = 99;
#declare Res = Add(_immu, 1)
In the second use of the macro, would it be required that the 'referenced' value
is also declared immutable?
ingo
Date: 28 Jun 2024 04:45:00
Message: <web.667e777b4bc5dc75c7a7971d6cde94f1@news.povray.org>
hi,
> > for example:
"modifier", yes.  +1.
the keyword modifier, more often than not I think, would be in close proximity
to the variable where/when it's used.  an advantage.
> directive.
if a variable's value can/will change "at runtime", #constant would simply be
misleading.
maybe "4.x" could have a revamped "SDL 2.0", with more "introspection" tools, so
we can write better, "type safe" code.
regards, jr.
Date: 28 Jun 2024 05:25:00
Message: <web.667e80794bc5dc7517bac71e8ffb8ce3@news.povray.org>
Just as an example how it works in an other language. In the Nim programming
language the following will not work as all proc parameters are immutable int
types. With Nim procs immutable arguments is the default, unless one uses "var":
proc dothing(a: int, b: int): int =
  a = a + b
  return a
let
  a = 1
  b = 2
let res = dothing(a, b)
This one will work as c is declared and assigned a value, c is immutable (let)
  let c = a + b
  return c
let
  a = 1
  b = 2
This will work as a is now of type var int, a mutable variable:
proc dothing(a: var int, b: int): int =
  a = a + b
  return a
var  a = 1
let  b = 2
a = dothing(a, b)
In the last example 'a' is 'var' in the proc and 'a' has to be "declared" as
'var', else the Nim compiler nags.
Changing a variable "declared" using 'let' into a 'var', or the other way
around, is not possible.
N.B. the last two examples can coexist next to each other in one file/program.
Depending on whether 'a' is a 'var' or not, the compiler chooses the proper
proc.
ingo
Date: 28 Jun 2024 09:12:10
Message: <667eb6aa$1@news.povray.org>
> for example:
Thanks, everyone, for the feedback & thinking toward v4.0.
The yuqk fork is intended to be a playpen for features like this.
Nothing about any given change or feature is set in stone. It might be
the current implementation for read only variables gets dumped in part
or in total after using it for while. I think it a decent approach, but
I've not used it nearly enough myself to know. It is, likely, the only
sort of global-ish thing doable with respect to identifier constant-ness
given the state of our current Scene Description Language (SDL).
With our SDL and parser, we don't have a cleanly scoped and typed
'variable' declaration system which allows more naturally for the
propagation and maintenance of constant information. (Any v4.0 SDL
re-work should probably treat scene identifiers complete apart from the
language variables)
My initial runs at some constant identifier support started with the
idea of all macro parameters being considered constant. However, I ran
across cases where users had macros which used the pass by reference and
change behavior.
I then started to look at a new 'const' keyword only with macro
parameters while thinking about how I might extend its usage before
concluding. There are a great many complications due how our language
and parser work which drive the need for language refinement or ugly,
complicated code infrastructure. I dropped the whole idea for years.
With yuqk, I've been forced to create prefixed language SDL keywords to
fix bugs and enable features. Over time, I started to see it's more or
less the same kind of weak scoping of functionality in our SDL. Where I
adopted prefixed keywords the source code too became more understandable
and manageable. I now plan, over time, to broadly adopt SDL keyword
prefixes. With this next R15 yuqk release I'll have three in keyword
prefixes in play with ii_ (input image), ip_ (internal
pattern/perturbation) and it_ (internal turbulence).
One day, not long ago, it hit me that maybe identifier prefixes would be
a way we could implement reasonably broad, useful constant-ness - though
not completely robust, constant-ness. When I started to really look at
implementing the idea, it turned out it was an amount of code work I
could manage.
While working in yuqk, the features implemented are often not exactly
what I'd wish for in v4.0! They are what I can manage and/or am forced
to do in the context of the yuqk/POV-Ray implementation as it is.
(BW) > Is that a scene-wide global thing?
Currently, it's always on and acts depending on context and what's
defined in each context. There isn't yet a way to configure with the
feature off as there is with no lower case identifier checking - which
is on by default in yuqk.
I think you're right, I need to go work on that configuration option
before releasing R15. We should be able to create executable(s) with the
checking off.
As for users switching the checking on and off on the fly... I think,
such control runs counter to the aim of the constant-ness feature itself.
(ingo, jr, et al)
I realize there is a fair bit of _xyz parameter and identifier usage.
It's in a lot of my own stuff too. Much of that will break - sometimes
while pointing out existing exposures too. I haven't played enough to
have a feel for the level of pain.
Given I'm going to delay to implement a build configuration option for
this feature, do you think some other prefix would be better? ('_r',
'ro_', 'r_', ?)
(jr)
Remember yuqk reduced the functionality of the 'optional' keyword to
just macro parameters due bugs and that when I really looked at broader
use, I found a new world space for confusing, extremely difficult to
debug, SDL bugs.
The larger view is the yuqk fork is breaking compatibility with official
POV-Ray releases.
I don't do it lightly because I want to be able to run scenes aimed at
official releases too, but breakage is unavoidable given I want to
address certain bugs, features and deficiencies.
Bill P.
Aside 1: I have still bugs and issues with the current global / local
dictionary behavior in v3.8+ to sort... Our implementation doesn't match
our documentation and we probably need a #top (or #upid (upvar n))
directive alongside #directive and #local.
Date: 28 Jun 2024 09:30:00
Message: <web.667eba654bc5dc75e21e5c0b25979125@news.povray.org>
> > > for example:
In the absence of a concrete example, I'm wondering how the modifier would be
"more flexible", and what "close proximity to the variable where/when it's
used." means.
> > directive.
> misleading.
Sort of.  I think the underlying idea is that it's not forever immutable, but
protected from unintentional and silent reassignment of it's value.
What about #protected?
It could be like function {}, where once declared, the parser throws an
(intelligible) error unless it's #undef'd before redeclaring.
The trick is balancing ease-of-coding with good coding practices, and new-user
friendly syntax so that we don't further steepen the learning curve.
Well YES.  Those sorts of things have long been wanted.
Camera location keyword/identifiers that would function like image_height, etc.
Identifier typing, especially for use in #read.
Differentiating things like vectors of different sizes, floats, etc.
View frustum coordinates or an internally defined 3D view frustum (maybe an
internal function that takes a length for the direction vector) that one can do
inside () tests with.
What really needs to be done is to draw a "map" of what we have coupled with
what we'd like to see.  That would function as a brainstorming vehicle, and a
to-do list.
Macros that people have written over the decades could be used as inspiration,
and I'm sure there are code libraries and things on GitHub, etc that have actual
c++ code or whatever language 4.x will be written in.
- BW
Date: 28 Jun 2024 09:40:40
Message: <667ebd58$1@news.povray.org>
> #end
> ingo
If I'm understanding you, no with respect to the macro, identifier pass
by reference issue.
As long as you have _immuInt as the first macro Add() parameter name,
the call can be Add(_immu,1) or Add(Res,1) and neither _immu or Res can
be changed by any #local or #declare use of _immuInt inside the macro.
That said, the Res identifier is not protected from someone writing:
     #declare Res = 42;
inside the macro while
     #declare _immu = 42;
will be illegal inside the Add() macro. So, it's not necessary the _
prefix immutability be indicated in both the macro parameter and more
global calling space - but it is a good idea, if you want protection
from someone making more global changes from within the macro.
Related. The hole in the prefix based constant-ness is that it is NOT
propagated into macros called. For example,
#macro Add(V1,V2)
     #local V1 = V1+V2;
     V1
    #declare Val99 = Add(_immu,1);
will still result in the _immu getting clobbered. The best practice
would be to always use macro parameter names with the _ prefix - unless
you are truly aiming to change identifiers by reference inside the
macro.
Bill P.
Date: 28 Jun 2024 11:51:01
Message: <667edbe5$1@news.povray.org>
    Mmmm, this can break some of my code /o\
    [like]
|          https://tube.interhacker.space/a/tth/video-channels        |
Date: 29 Jun 2024 01:00:00
Message: <web.667f94264bc5dc75c7a7971d6cde94f1@news.povray.org>
hi,
> > > > [Cousin Ricky]
> > > > for example:
> used." means.
the "close proximity" thing is shown in CR's suggestion, note the 'const'
immediately in front of the variable in question.
"flexible", for instance, a (say) '#constant' directive alone and the macro
definition would still offer no "visual clues" wrt the arguments also could not
be used in expressions either.
(and remember, I'm no "language designer" either :-))
> > misleading.
see reply to WFP.
> Well YES.  Those sorts of things have long been wanted. ...
> to-do list.
agree, a in-one-place collection of things needing doing, plus "feature
requests", is very much needed.
regards, jr.
Date: 29 Jun 2024 01:05:00
Message: <web.667f94f34bc5dc75c7a7971d6cde94f1@news.povray.org>
hi,
just a couple of thoughts.
> a way we could implement reasonably broad, useful constant-ness - ...
> 'ro_', 'r_', ?)
"democracy" eh ?! </grin>.  given those options, 'ro_' would be my choice, as
it's "mnemonic".
having read ingo's Nim language examples, I really like the "everything is
immutable unless" approach.  safe.  perhaps all macro args (as you wrote
somewhere) ought to be "ro" by default, and an explicit 'upvar N' required for
every exception ?  (that (upvar N) :-) would be _seriously_ nice to have)
regards, jr.
Date: 29 Jun 2024 14:36:26
Message: <6680542a$1@news.povray.org>
On 6/29/24 01:00, jr wrote:
> hi,
>> 'ro_', 'r_', ?)
> it's "mnemonic".
Yeah, and ro_ fits with my keyword prefix direction too.
I've been thinking about those examples too & my response to Ingo's
question. I failed / bailed on my initial attempts to make a macro
parameters constant always - but success would have meant a SDL change
much more likely to break current code than an 'ro_' prefix. I hadn't
thought much at all about a keyword to change defaulted read-only to
something mutable via a new keyword.
It might be we could check that the mutability of the parameter in the
macro matches the caller's ID mutability, but there are limits to how
much checking like that we can do given SDL isn't compiled and linked.
We'd be paying the price of the overhead on every call to the macro.
 From what I've seen people mostly use the macro 'pass by reference and
change' and '#declare ID' as mechanisms to return multiple values or to
define what they want global as with the yuqk munction concept compiling
users functions only once. (We now have the tuple return and assignment
mechanisms in v3.8.)
Another thing which might be possible nearer term, would be to make
mixed use of #declare and #local with the same variable name inside
macros illegal in yuqk (or in just the debug compile).
See the attached file for a few examples of how mixing one identifier
name with both #local and #declare can result in instability. The macro
parameter - change by reference - issue aside.
We should mention too, for those stumbling across this thread later,
that a good solution for all the macro-ish exposures to inadvertent
identifier change is to use functions when dealing with just math and a
return a value.
Bill P.
Download 'instabilitywithlocalanddeclareuse.txt' (3 KB)
Date: 29 Jun 2024 14:55:00
Message: <web.668057a14bc5dc751f9dae3025979125@news.povray.org>
Well, this has been brought up by myself and other before,
I think the easiest thing to do would simply be use a collaboration tool or
project management tool and get _something_ started.
https://opensource.com/business/15/7/five-open-source-alternatives-google-docs
Then we could start with a general outline of what we _have_ complete with
hyperlinks to the wiki or whatever works best to illustrate the concept.
Then maybe separate documents that "mirror" the source code, where we could
strip out all of the extraneous non-code stuff, for enhanced readability (with
links to original).  Then people with coding experience could read and comment
on the code, and perhaps even insert hyperlinks between where one piece of code
utilizes a variable, and the (faraway) place in the code where that variable
gets updated last.
Obviously to-do list and desired features.
Coders could begin scribbling scratch code and other people could be inspired
and take it a step further.
The advantage here is that if the outline structure is maintained well, it'll be
a lot easier to find than sifting through 30 years of haphazard forum posts.
Users could then have a personal "wiki page".
FAQ type material could be organized to provide "one code example for every
keyword", micro-tutorials on coding methods / algorithms / tricks, working
examples of tricky syntax, etc.
Macros could be assembled so that people could look things up in an index and
find what they were looking for.
Desired features could be exemplified with macros, and then converted to source
code by people who have the c++ experience but don't understand the goal /
algorithm needed.
And since it should pretty much be all text, with hyperlinks to graphics,
articles, pdf documents, websites, etc, it should be fairly small to store local
copies - which means every collaborator has a copy / backup.
- BW
Date: 29 Jun 2024 15:40:00
Message: <web.668062ca4bc5dc75c7a7971d6cde94f1@news.povray.org>
hi,
a lot of points/issues "touched on", food for thought.  will, in the coming
days, try and set out the response "gut feeling" tells me, structured, for your
inbox.
@Bald Eagle.
a wiki s/ware would be perfect.  personally, I think 'fossil' should "be on the
table".
> ... it should be fairly small to store local copies ...
no need to worry, in this day and age.  (the machine which took the place of the
'crow' earlier this year has two M.2 "drives" -- 1.5T total, not even £100)
common access will be the "bug bear" imo.
regards, jr.
Date: 29 Jun 2024 16:35:00
Message: <web.66806fcd4bc5dc751f9dae3025979125@news.povray.org>
> table".
I'm game.  I can download that and we can see about getting something started.
> (the machine which took the place of the common access will be the "bug bear" imo.
We are truly 2 people separated by a common language.
- BW
Date: 29 Jun 2024 17:20:00
Message: <web.668079b44bc5dc75c7a7971d6cde94f1@news.povray.org>
> > table".
<https://www.fossil-scm.org/home/doc/trunk/www/index.wiki>
</grin>.  "struggling against the same s/ware configuration", more like.
apparently, the GBP currency sign (too) makes the web l/f "unhappy"; I wrote,
"showing off", that crow's "replacement" has 1.5T (truly mind-boggling "space",
on two M.2 SSDs), for under 100 of our currency units; cheaper still now.
regards, jr.
Date: 29 Jun 2024 17:35:00
Message: <web.66807cdd4bc5dc751f9dae3025979125@news.povray.org>
I'm already "up and running" - just need to figure out how you log in to the
system to start doing stuff.
- BW
Download 'setup.png' (51 KB)
Preview of image 'setup.png'
Date: 30 Jun 2024 02:05:00
Message: <web.6680f5014bc5dc7517bac71e8ffb8ce3@news.povray.org>
> language
I should have added one more option as it does what one can do with macro's.
Note there is now no output type specified and thus no return value. 'a' is
modified "in place".
proc dothing(a: var int, b: int) =
  a = a + b
var  a = 1
let  b = 2
dothing(a, b) # or a.dothing(b)
echo a  #printed result is sum of and b
ingo
Date: 2 Jul 2024 11:32:25
Message: <66841d89$1@news.povray.org>
>>> 'ro_', 'r_', ?)
>> choice, as
>> it's "mnemonic".
Release 15 of the yuqk fork has moved to the ro_ prefix to indicate the
identifier is read-only. The build configure script option to disable
the feature was added and is: --disable-read-only-identifiers
Bill P.
Date: 8 Jul 2024 08:15:00
Message: <web.668bd7624bc5dc75c103d2725979125@news.povray.org>
Curious if anyone has the ability and inclination to run this in server mode, or
alternatively if someone knows of a peer-to-peer (P2P) style collaborative
document editing FOSS software that would serve our purpose.
- BW
Date: 9 Jul 2024 12:00:00
Message: <web.668d5e774bc5dc7517bac71e8ffb8ce3@news.povray.org>
There is http://chiselapp.com/ that hosts fossils (kind of like github) and you
can control who has access to the data. I used it in the past, worked fine then
and then not and then again. Seems to look ok now.
ingo
