POV-Ray : Newsgroups : povray.pov4.discussion.general : Multiple render jobs in a single instance Server Time
14 Dec 2025 18:41:14 EST (-0500)
  Multiple render jobs in a single instance (Message 1 to 10 of 10)
Subject: Multiple render jobs in a single instance
Date: 21 Jan 2016 20:46:48
Message: <56a18a08$1@news.povray.org>
I think it could be a good idea to support multiple render jobs running
in parallel in a single instance of POV-Ray. You could manage them like
downloads in a download manager or bittorrent.
Why, do you ask? Because when running multiple instances it can get
confusing as to which instance is currently running. Over the last week
I've accidentally stopped a long render a few times because I clicked on
the wrong icon in the taskbar.
Also, it resolves the issue where some files are open in one instance
but not another, and POV-Ray does not correctly remember which files
were open when starting a new instance.
Lastly, the "recent files" list at the bottom of the File menu may get
messed up with all the separate instances.
I don't think this is a high priority, but I thought I'd throw the idea
out there.
Mike
Subject: Re: Multiple render jobs in a single instance
Date: 22 Jan 2016 02:40:36
Message: <56a1dcf4$1@news.povray.org>
Don't you get a warning if you try to stop a long render?
Date: 22 Jan 2016 16:08:41
Message: <56a29a59$1@news.povray.org>
Hash: SHA256
> running in parallel in a single instance of POV-Ray. You could
> manage them like downloads in a download manager or bittorrent.
> get confusing as to which instance is currently running. Over the
> last week I've accidentally stopped a long render a few times
> because I clicked on the wrong icon in the taskbar.
> instance but not another, and POV-Ray does not correctly remember
> which files were open when starting a new instance.
> get messed up with all the separate instances.
> idea out there.
You know, of course, that the windows version has a render-queue, in
which you can put the different jobs.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlaimlkACgkQhKAm8mTpkW2XnAQAsgiFdbSqd6tKlPBH2WWK6dwS
HgMkZsJw2RbRdwrVPqzUlWKI81e0eQXUxxfXa1rn+sVfz+HMOLl+dk/GhWYV8hCR
5SX6X5G2R17r3zJK+ANRJUQp2e2l8b5/KePMJretpZtxm+bWBIzLR2R/Gf8urzdV
CuTv6PAZiKUgB8o4fcc=
=9JCZ
-----END PGP SIGNATURE-----
Date: 22 Jan 2016 19:07:26
Message: <56a2c43e$1@news.povray.org>
I did know that, actually.
Mike
Date: 22 Jan 2016 19:07:57
Message: <56a2c45d$1@news.povray.org>
Unfortunately, I still get confused sometimes and click through the warning.
Mike
Date: 23 Jan 2016 09:50:00
Message: <web.56a391f7667bcfdcadb2e4f80@news.povray.org>
Ok, Mike thinks of a Render-Que ahere multiple "Scripts" render at the same
time,
and where you can give each of the renderings more or less priority.
In my experience this will only make sense, if it will survive a computer-reboot
without big problems.
Date: 23 Jan 2016 15:25:54
Message: <56a3e1d2$1@news.povray.org>
> time,
That is true. You should be able to continue where you left off after a
reboot.
(Currently you can use POV-Ray's +C switch. But does this work with
multiple scenes?)
Mike
Date: 23 Jan 2016 15:50:00
Message: <web.56a3e6da667bcfdcdf2858e60@news.povray.org>
> > time,
> reboot.
> multiple scenes?)
Internally POV-Ray 3.7 can render multiple scenes at the same time. There is
just no user interface to make use of this feature.
Date: 13 Feb 2016 02:40:00
Message: <web.56bedd43667bcfdcadb2e4f80@news.povray.org>
Possibly there is some "Overhead" in doing trhese switches often, unless it
would definitely dedicate CPU-Cores to each Task?
Date: 13 Feb 2016 04:40:00
Message: <web.56bef8e4667bcfdce5b2956d0@news.povray.org>
The overhead of rendering multiple scenes in a single instance is less than
running multiple instances and rendering in each.
