POV-Ray : Newsgroups : povray.pov4.discussion.general : <no subject> Server Time
30 Apr 2024 22:05:10 EDT (-0400)
  <no subject> (Message 1 to 3 of 3)
Subject: <no subject>
Date: 20 Dec 2012 04:55:02
Message: <web.50d2df49c23a6d9be007bed0@news.povray.org>
Hello,
First: English is not my mother language. I do my best to be clear. One way to
make sure that my message is clear is to reformulate my sentences.
I postes a message on a different section, but I think that it could be posted
here as well.
Question 1 :
Would it be difficult to separate the renderer from the user interface ?
ie:
Would it be difficult to embed the function that reads the source code (that
represents the scene) and generates an image into a separate process ?
Question 2 :
Are the parsing function (that reads the scene description) and the rendering
function well decoupled ?
ie:
Is the source code of the parser well isolated from the source code of the
renderer ?
Explanation for the first question :
When porting a software, user interface is often painful. Furthermore, Povray's
user interface is essentially a code editor. It could be replaced by any serious
code editor, such Eclipse.
From my point of view, there is no reason to maintain the Povray's user
interface.
I guess that Povray does not use any OS dependant library for the rendering.
We could see the renderer as a compiler.
Explanation for the second question :
Povray's language for scene description is quite archaic (for today's
standards).
My impression is that it was first a "descriptive language" (such as XML).
Then variables and macros were added, to make it a very basic "programming
tool".
If we can isolate the renderer code, we could interface it with languages such
Perl, Python, PHP... All the parsing and the hard work would be handled by the
(Perl, Python, PHP) interpreter. Furthermore, we could use the entire collection
of libraries available for these languages.
Best regards,
Denis
Subject: Re: <no subject>
Date: 20 Dec 2012 12:51:52
Message: <50d35038$1@news.povray.org>
Am 20.12.2012 10:50, schrieb denis.beurive:
As a matter of fact, there is no such thing as "the" POV-Ray user
interface; there is a GUI for Windows, and there's a command-line
interface for Linux. (You can also start a POV-Ray render from a Windows
command prompt, but it's a bit messy because it always starts the GUI,
and/or delegates the render to an already running instance of it.)
> interface.
It is maintained as a convenience for Windows users: While good code
editors are part of every Linux distro, Windows doesn't come with one
out of the box.
Perfectly true.
It is already seen as such.
> standards).
> tool".
Yes, that is indeed the case.
The collateral damage of this would be a fragmented user community: Some
would use Perl, some Python, etc.; and it would be impossible to
exchange parts of scenes between those factions.
It would also leave new users to the question, which language to use,
and require them to install a 3rd-party tool (the compiler or
interpreter for that language).
The only way around this is retaining /one/ inbuilt language as /the/
standard language for POV-Ray scene descriptions.
Furthermore, creating a scene is still primarily descriptive work, while
all of the mainstream languages are imperative in nature, making them
comparatively cumbersome for the job.
I'm therefore convinced that the proper thing to do is a thorough
overhaul (or even redesign) of the SDL.
Date: 21 Dec 2012 03:22:45
Message: <50d41c55@news.povray.org>
> interface.
For most Windows users I suspect setting up Eclipse is not something
they particularly want to do. In the past I've been forced to use it for
Java stuff and it totally sucks compared to eg the Visual Studio IDE. If
anything the POV editor should be improved and upgraded with things like
context-sensitive auto-complete, inline help etc. I know Mike Raiford
was working on a POV editor based on the Visual Studio shell and it
looked very promising.
You can write SDL files from your own code in whatever language you
want. This is pretty common when generating complex scenes based on
simulations etc.
