POV-Ray : Newsgroups : povray.pov4.discussion.general : comma at end of last element in list Server Time
15 Mar 2026 06:30:25 EDT (-0400)
  comma at end of last element in list (Message 1 to 5 of 5)
Subject: comma at end of last element in list
Date: 15 Oct 2008 14:18:19
Message: <48f633eb$1@news.povray.org>
What I'd like to see is an allowed comma at the end of the last element in a list.
This would facilitate the populating of lists from within a loop.  There's now the
need (AFAICT) a silly check for the last element to omit the comma.
Dan
Subject: Re: comma at end of last element in list
Date: 15 Oct 2008 14:35:01
Message: <web.48f636eeeded49c981c811d20@news.povray.org>
ing of lists from within a loop.  There's now the need (AFAICT) a silly check for the
> Dan
Usually I workaround by adding the comma before the number, that way there is no
comma at the end of the list.  This works usually because most items that I have
created that use lists (meshes, splines, polygons) have a float preceding the
list, usually the number of items conatined in the list.
-tgq
Date: 15 Oct 2008 15:30:04
Message: <48f644bb@news.povray.org>
Trevor G Quayle <Tin### [at] hotmailcom> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 14 lines --]
> > Dan
  Also you could skip using commas completely. Just put your elements in
parentheses (to avoid ambiguity in situations like "2 -1") and you don't
need commas at all.
Date: 15 Oct 2008 15:55:00
Message: <web.48f649a2eded49c981c811d20@news.povray.org>
list.  This would facilitate the pop
ulat
a.
> > > Dan
> need commas at all.
Yes that may be better.  I was unaware that I could skip the commas in those
types of items (I knew you could in primitives).  Is this stated anywhere in
the docs explicitly or is one of those read between the lines to discover?
-tgq
Date: 15 Oct 2008 16:35:37
Message: <48f65419@news.povray.org>
  I don't remember the docs well enough to say for sure, but I would say
it's more or less an undocumented feature.
