POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 sor{} fixes / changes. (yuqk R20 v0.6.14.0) : Re: Suggest v4.0 sor{} fixes / changes. (yuqk R20 v0.6.14.0) Server Time
20 May 2026 12:04:26 EDT (-0400)
Date: 21 Sep 2025 06:36:12
Message: <68cfd51c$1@news.povray.org>
On 9/15/25 19:49, William F Pokorny wrote:
> The idea with both 'caps' and 'intervals' is to add inbuilt ways for the
> sor{} to be broken apart and the pieces textured, used in CSG or for
> debug and modeling.
An additional change with the sor{} for R20 of yuqk is to allow sor
references to existing sor identifiers - while permitting changes to the
caps, open and intervals keyword settings(*). In other words, today, if
you want two sor shapes where the only difference is the open setting,
you have to create two complete sor{} blocks including the point list
and the 'open' keyword or not.
It is the case today that using sor { Sor00 } is no different than
object { Sor00 } in that both allow only differing object modifiers
within the braces after the sor identifier.
There is also no type checking the identifier reference matches the type
of the block wrapper itself. While the debug compile of yuqk has already
implemented some type checking for text{} and ???, R20 of yuqk will
always verify the ID type for the updated sor{}. It must to enable the
keyword settings of a referenced sor ID to later be modified.
Attached an image and the scene file used to create the four sub images.
Bill P.
(*) - I thought I had the code for this in hand a week ago, but nope. I
believe I've now got a clean implementation...
Download 'parsingchanges01.pov.txt' (4 KB) Download 'parsingchanges.png' (71 KB)
Preview of image 'parsingchanges.png'
