POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 sor{} fixes / changes. (yuqk R20 v0.6.14.0) : Suggest v4.0 sor{} fixes / changes. (yuqk R20 v0.6.14.0) Server Time
20 May 2026 13:07:52 EDT (-0400)
Date: 15 Sep 2025 19:49:45
Message: <68c8a619$1@news.povray.org>
The bug fixes(a) and control point relaxations for the sor{} in the next
yuqk release were discussed in the thread:
https://news.povray.org/povray.documentation.inbuilt/thread/%3Cweb.689b6c79e72c05b2bc0c1c5925979125%40news.povray.org%3E/
The next yuqk release is also adding two new keywords to the sor{}. One
is 'caps' and the other is 'intervals'.
The caps changes align what was done for yuqk's text{} update:
https://news.povray.org/povray.pov4.discussion.general/thread/%3C67e41261%241%40news.povray.org%3E/
The intervals keyword is followed by a string of 0 and 1 values which
allow particular sor{} curve segments to be kept or not.
The middle image row used:
     intervals "10101"
which, left to right, indicates only the first, third and fifth of the
five total sor{} segments are to be used.
The idea with both 'caps' and 'intervals' is to add inbuilt ways for the
sor{} to be broken apart and the pieces textured, used in CSG or for
debug and modeling.
The second row rotates the sor by -10*x and the third row by -45*x to
better see the sor segments and caps, respectively.
Bill P.
(a) - Except for adjusting an older yuqk update removing the
too-generic, single value EPSILON use in the sor code. In recent testing
I found cases - like in the attached image - with tight, segment turns
where those A,B,C,D internal values needed to be zeroed at closer to the
old official POV-Ray EPSILON of 1e-10. I settled specifically on
4.4e-12, but things are being fudged here - so we'll see how the newer,
new zeroing limit holds up.
Download 'sor_v4_suggest.png' (41 KB)
Preview of image 'sor_v4_suggest.png'
