POV-Ray : Newsgroups : povray.pov4.discussion.general : User changes. yuqk / v4. Options re-work status. : Re: User changes. yuqk / v4. Options re-work status. Server Time
15 May 2026 09:47:14 EDT (-0400)
Date: 13 Jun 2025 16:34:07
Message: <684c8b3f$1@news.povray.org>
On 6/13/25 07:38, Thorsten wrote:
> There is a good reason these are identifiers and not keywords (any
> more). The architecture had a lot of separation issues in POV-Ray 3.6,
> MegaPOV and before that kept getting worse, and prohibited a lot of
> features that are useful.
> The most notable is that the scene and the rendering can be separated.
> That is, you do not need to re-parse a potentially complex scene for
> hours just the render it in a higher resolution. There isn't even a
> reason to not move the camera after parsing (as the real-time ray-
> tracing feature shows).
> The main problem has always been that a GUI was never developed for
> these features. So the question you probably want to ask yourself it if
> it really makes sense to throw all this overboard for an extremely
> complex command-line interface...?
As always thank you for the background. I think I followed most of what
you wrote. I expect my inability to write clearly has led to some
confusion too. I'm sure too, I don't see all the obstacles I might
encounter or introduce as I try and complete this re-work...
It's also true my ideas for the user command-lind / ini 'options' in
this thread are some of the least developed / refined of my re-work effort.
As you know, the only method which doesn't require near-complete
re-parsing of scenes for each frame today is the rtr camera list one. It
might be the view internal code aspect is further along that my quick
read-overs have led me to think, but it's not something working today
for users beyond setting up an initial 'view' / camera view.
In other words, I'm not aware of any 'working method' to implement your
example of rendering a scene again at a higher resolution without
re-running the entire render - including too the cli/ini options parsing(*).
(*) You can distort each animation's frame images by twiddling with the
image_height and image_width identifier values if, for example, these
'pretend keywords' have been used to defined the camera. But, this
capability also touches on the exposure carried with the current
implementation.
What I'm re-working in these last couple months is setting more things
up in the options parsing which runs prior to the virtual front end
(vfe) starting. The 10 or 12 'pretend keywords' / identifiers like
image_width are set as vfe starts today. Nothing with respect to that
will change any time soon due the re-worked options.
In aiming to move the global_settings{} block stuff into the 'options'
cli/ini parsing code, for example, I am pushing more 'keywords' out of
the parser and into the options parsing as flags / ini-options where
they'll get digested once rather than for each frame as our code stands
today.
With respect to this thread in particular and the cli/ini declare=<id>=
option, I'm talking about changing / extending what today might be done
in an ini file with a set of lines like:
declare=Int00=111
declare=Int01=222
declare=Int02=333.456
and parsed during the options setting phase with, say,
'include_ini=MyInts.ini'.
With the planned approach in this thread it would become instead a file
with the lines:
Int00 111
Int01 222
Int02 333.456
and
+-ui_"MyInts.ini"
Except I can now type check the input values and they become something
read only accessible as global integers inside the parser (via parser
functions). There is, of course, some effective 'look up the value'
process whether done via a function call or parser identifier access.
Aside: Though I don't plan to go this way at present, a hybrid approach
is possible - whether declare=.=. or as this new alternate +-ui_ method
- nothing stops us from setting identifiers Int00, Int01 and Int02 to
integer values before the parser runs in addition to enabling the parser
function accessible method or even in place of it.
Lastly, I've only ever really used POV-Ray on linux/unix/aix systems.
I'm not familiar with the windows (or osx) POV-Ray GUIs and expect I'm
largely ignorant of most GUI support implications in general.
A reminder the yuqk fork is a linux/unix only v4 playpen - though
hopefully mac/osx compiles work too.
Bill P.
