POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggested v4.0 patch for openexr read where large floats : Re: Suggested v4.0 patch for openexr read where large floats Server Time
21 Jul 2026 16:39:55 EDT (-0400)
Date: 24 Jan 2022 06:54:10
Message: <61ee9362$1@news.povray.org>
On 1/23/22 18:57, William F Pokorny wrote:
> Found where incoming exr files are at floats and the file has channel
> values larger than about 2^16 we end up with +inf color channel values
> internally.
I forgot to mention, should you run into one of these exr files with
values too large for POV-Ray's current exr reader, you can use
converters to get to an hdr file.
I was able to use: 'iconvert sunflowers_4k.exr sunflowers_4k.hdr'
The openimageio-tools based tooling is able to handle the >2^16 channel
values and appears to correctly convert to 'workable' hdr files(a)(b).
Bill P.
(a) - An attempt to use incovert from full float encoding to half float
ran and looks OK external to POV-Ray in that the values are reduced to
what fits in a half float. However, on attempting to use the half float
form HDRI, I still had the speckling problem - though the signature of
the speckles was somewhat different. Not sure what's happening there.
(b) - The hdr format supports less precision and dynamic range than exr
files, so, it's a non-ideal work around.
