POV-Ray : Newsgroups : povray.off-topic : Text to SVG Server Time
21 Jun 2025 03:39:43 EDT (-0400)
  Text to SVG (Message 1 to 9 of 9)
Subject: Text to SVG
Date: 28 Feb 2016 21:30:01
Message: <web.56d3aca979b2a9385e7df57c0@news.povray.org>
Was wondering if anyone knew of some software or (nowadays) a website that would
take text and reliably convert it (in the chosen font) to discrete SVG objects.
Either that, or explain how to make use of these "SVG fonts" I've seen
mentioned,
or how to use the font file itself to sort of directly create an SVG object.
The end of my work flow is usually SVG ---> DXF  ----> import to proprietary
software, and the text never seems to "make it through", and the proprietary
software seems to handle text horribly.
Thanks!
Subject: Re: Text to SVG
Date: 28 Feb 2016 22:19:03
Message: <56d3b8a7$1@news.povray.org>
> mentioned,
> Thanks!
Have you tried InkScape? That might work for you.
Mike
Date: 28 Feb 2016 23:10:00
Message: <web.56d3c39cce90ff255e7df57c0@news.povray.org>
Thanks Mike.
Naturally, I have tried InkScape, and for some reason either it doesn't work, or
I'm doing it wrong.
Still learning, so probably the latter  ;)
Anything specific you suggest that I try?
Assume I know absolutely nothing.
LaserCAD just gives me empty "bounding boxes" instead of text when I import the
DXF that I export from InkScape.   :(
I'd love to be writing directly to DXF from Visio (or POV-Ray  :D) , but that
doesn't seem to work too well if at all.
Date: 29 Feb 2016 12:43:41
Message: <56d4834d$1@news.povray.org>
> mentioned,
the SVG syntax (it's text... or rather xml, which is text) is rather
simple, if all you need is a unformatted text (aka single line) it can
be as simple as using a template and performing substitution of the text
in it.
The more complicated issue is giving the right dimension to the
container. Height for a single line can be easy, but width for a
non-mono font is going to be complex.
http://www.w3schools.com/svg/svg_text.asp
http://tutorials.jenkov.com/svg/text-element.html
https://www.w3.org/TR/SVG/fonts.html
Date: 29 Feb 2016 18:40:00
Message: <web.56d4d5ddce90ff255e7df57c0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
Sorry, I think you misunderstood my goal / intent.
What I want to do is take "text" and convert it into a "drawing" - a line, or a
path, or whatever would make it not a "font" or "typeface", but an outline of
the glyph.
Text, as such, does not seem to make it through the SVG to DXF to import
sequence, and so I need to find a way to get the letters to show up anyway.
Date: 1 Mar 2016 02:35:22
Message: <56d5463a$1@news.povray.org>
> the glyph.
Have you tried : https://cloudconvert.com/svg-to-dxf ?
They claims to support text in svg, and svgfont is just a way to specify
exactly the glyph inside the svg instead of using a third party font and
format (such as ttf or other)
Now, if you want to replace a filled drawing of a glyph with only its
boundary, that's another problem.
I wonder if fontforge is able to load or import svgfont... seems to:
https://fr.wikipedia.org/wiki/FontForge
Date: 1 Mar 2016 07:15:55
Message: <56d587fb$1@news.povray.org>
> the glyph.
> Thanks   :)
In Inkscape, yo can select a piece of text, and use the Object to Path
command to turn it into non-text.
Mike
Date: 1 Mar 2016 07:31:13
Message: <56d58b91$1@news.povray.org>
And Blender can mesh-ify it.
Regards
Date: 1 Mar 2016 09:25:00
Message: <web.56d5a52bce90ff255e7df57c0@news.povray.org>
> Regards
>      Stephen
Aha.  Still learning all of this new stuff.  Thanks for the tips.
I'll probably play around with it some later on and see how it works out.
Thanks!   :)
