POV-Ray : Newsgroups : povray.off-topic : Hello again Server Time
25 Feb 2026 07:25:25 EST (-0500)
  Hello again (Message 36 to 45 of 55)
Subject: Re: Hello again
Date: 7 Jul 2015 14:00:01
Message: <web.559c1285952282f0b426f96a0@news.povray.org>
scott <sco### [at] scottcom> wrote:
> > One type of AO from Fragmentarium requires 6
> > samples to be taken from the DE. Because the DE is smooth, it makes for a nice,
> > fast (not quite free) solution (also works with POV isosurfaces), but I wouldn't
> > call it AO. It's a proximity pattern :)
> Yes it depends how many rays and how far you want to step. You can also
> re-use the last primary ray DE value before intersection (and the
> initial shadow ray values) as an even cruder approximation.
It all depends on what you want, but personally I don't like the idea. Even if
that sample was added to three others (forming a camera-oriented tetrahedron),
there's still a likelihood that those last DE samples will have been taken at
different relative distances to the surface across the render. Does that make
sense?
> When thinking about optimising distance field renderers I always get a
> feeling that you should be able to do something clever with voronoi
> diagrams but I have never worked out what yet...
Hmm. Are you talking about breaking up the DE into separate regions, so that no
particular region will have too many components (shape operations)? If so, what
happens when a shadow or reflection ray needs to travel between regions?
Date: 7 Jul 2015 21:33:04
Message: <559c7dd0$1@news.povray.org>
Am 07.07.2015 um 19:55 schrieb Orchid Win7 v1:
> I wonder if a piece-wise linear curve would be any faster... (Not that
> POV-Ray can do that.)
Not? Well, you'd be surprised...
Even if POV-Ray didn't have its "select()" function, I guess some
creative use of "abs()" could get you there.
Date: 8 Jul 2015 03:43:57
Message: <559cd4bd$1@news.povray.org>
>> I have literally no idea what you're talking about. Are you using a
>> different release version to me or something? I have no problems here.
> 3.7 official.
> The attached shows artifacts present at various accuracies for the function
> sqrt(x*x+y*y+z*z)-1. max_gradient set to 100 for all spheres, which is more than
> enough.
> The first might look acceptable... but just try adding a pattern displacement,
> and it'll become obvious that the accuracy is set too high.
Assuming you've got no pattern displacement in any of those images, it
looks to me like it's something to do with the shadow ray being started
too close to the surface (and hence the tracer immediately thinks the
shadow ray has been blocked by the isosurface itself).
Date: 8 Jul 2015 03:53:28
Message: <559cd6f8$1@news.povray.org>
> sense?
Indeed, my personal goal is to rather keep the scene moving at a decent
frame rate (whilst adding more complexity) rather than towards a more
realistic render.
Yes, I'm thinking that with complex scenes I am still always computing
the distance field for every single object. What I think would speed
things up is if you could group objects together and create a kind of
much simpler conservative "group" distance function. I guess a kind of
n-tree structure where you only need to do a relatively cheap check at
each level to rule out certain nodes that you don't need to go down and
evaluate any further. I guess POV does something similar.
You would do this for every distance field evaluation, so it wouldn't
matter if a ray jumped from one region to another.
I'm also not sure if such a scheme would actually make much improvement
on a GPU.
Date: 8 Jul 2015 13:20:00
Message: <web.559d5a77952282f0b426f96a0@news.povray.org>
> > sqrt(x*x+y*y+z*z)-1.>
I should have guessed that, since I ran into shadow ray problems last summer
with the raymarching stuff. The shadow ray's origin had to be spaced from the
initial hit point (by backing it up toward the camera or outward from the
surface), or else artifacts would appear.
Attached is the same scene, this time with no_shadow applied to the isosurfaces.
Making the light_source shadowless also works.
I vote for a new keyword addressing this issue! Not only are the artifacts ugly,
but I would imagine they also slow down render times when aa is used.
Download 'isospheres-ns.png' (69 KB)
Preview of image 'isospheres-ns.png'
Date: 8 Jul 2015 13:44:43
Message: <559d618b$1@news.povray.org>
Question: Does the problem go away if you make the spheres bigger? Like,
say, 10 units across instead of just 1?
As I recall, POV-Ray tends to dislike rendering either very tiny or very
large objects. Floating-point precision issues and all.
(Most particularly, I believe the minimum distance for a shadow ray to
travel is a hard-coded constant, which might be too small if the
isosurface itself is very tiny.)
Date: 8 Jul 2015 13:50:00
Message: <web.559d621a952282f0b426f96a0@news.povray.org>
Right. I was either working off an incomplete thought from last year, or another
problem altogether :/
> on a GPU.
Maybe voronoi diagrams aren't needed. Perhaps a simple 'buckets' system would
suffice, where space is divided into cubic cells, with each cell containing just
a few objects. Of course, any object overlapping cell boundaries will have to be
held in more than one bucket...
Date: 8 Jul 2015 16:05:01
Message: <web.559d8162952282f0b426f96a0@news.povray.org>
I just ran some tests. Scaled the isosurface and zoomed the camera; adjusted the
function radius and scaled the object; multiplied/divided the function to change
the gradient's falloff rate... all at values between .01 and 100. No change. You
end up just needing to adjust the accuracy and max_gradient, but the end result
is always the same.
I was hoping that with 64 bit would come a more precise epsilon value, but it
didn't turn out that way :( Was it a misunderstanding on my part, or to keep
POV-Ray rendering the same on different architectures, I wonder?
Date: 9 Jul 2015 02:52:34
Message: <559e1a32$1@news.povray.org>
> is always the same.
This is completely off-topic!
If you start the shadow ray a little further out, you'll just get the
same artifacts but in a slightly different place. With a point light
casting a hard shadow-line on a curved surface like that it's always
going to amplify any numerical precision issues, as all the pixels
around the shadow-line will have very similar shadow ray direction
(which are very close to tangent to the surface).
A realistic solution is to use a very small area light, to average out
the area around the shadow-line.
Date: 9 Jul 2015 03:03:33
Message: <559e1cc5$1@news.povray.org>
>> on a GPU.
I think the tricky part would be deciding which cells an object goes
into, without either limiting yourself to very simple objects or having
to manually figure it out.
But assuming you can get around that problem, then yes either into cubic
cells, or I was initially thinking of non-uniform "groups" that could
just have bounding spheres. With either method you could go down an
arbitrary depth depending of cells-within-cells on scene complexity.
