POV-Ray : Newsgroups : povray.off-topic : Hello again Server Time
4 Feb 2026 23:25:21 EST (-0500)
  Hello again (Message 31 to 40 of 55)
Subject: Re: Hello again
Date: 6 Jul 2015 18:00:00
Message: <web.559af9b5952282f0b426f96a0@news.povray.org>
Le_Forgeron <lef### [at] freefr> wrote:
> > Distance Fields are similar to isosurfaces, but the isosurface value is
> > used to store the minimum possible distance to any surface. Then it
> > makes your raymarcher algorithm very simple:
> > do{
> >  point = rayStart + rayDirection * distance
> >  stepSize = EvaluateDistanceField(point)
> >  distance += stepSize
> > while( stepSize > someVerySmallAmount)
> > The functions and methods are very similar to isosurfaces:
> > http://www.iquilezles.org/www/articles/distfunctions/distfunctions.htm
> > There are also some clever tricks you can do to get soft shadows and
> > ambient occlusion for free.
> ahem...
> The described distance fields are exactly povray isosurface :
> first vector (vec p) is the position, and the other optional parameters
> are the formula's specific constants if any. (the threshold parameter of
> povray is a bonus to adjust the surface, but you can keep it at 0 and
> change the formula instead).
So why do POV's isosurfaces render with so many artifacts? Take a simple sphere
function. Should turn out almost flawless, but it doesn't! POV's isosurfaces
look all sliced up, even with an ideal max_gradient. Lower accuracy values only
raymarching code I've used looks a lot better. Why?
Date: 7 Jul 2015 02:49:17
Message: <559b766d$1@news.povray.org>
> Free ambient occlusion? How free?
Depends how accurate you want your AO :-)
> One type of AO from Fragmentarium requires 6
> samples to be taken from the DE. Because the DE is smooth, it makes for a nice,
> fast (not quite free) solution (also works with POV isosurfaces), but I wouldn't
> call it AO. It's a proximity pattern :)
Yes it depends how many rays and how far you want to step. You can also
re-use the last primary ray DE value before intersection (and the
initial shadow ray values) as an even cruder approximation.
When thinking about optimising distance field renderers I always get a
feeling that you should be able to do something clever with voronoi
diagrams but I have never worked out what yet...
Date: 7 Jul 2015 03:24:38
Message: <559b7eb6$1@news.povray.org>
On 06/07/2015 10:57 PM, Samuel Benge wrote:
> Le_Forgeron<lef### [at] freefr>  wrote:
>> ahem...
I have literally no idea what you're talking about. Are you using a
different release version to me or something? I have no problems here.
Date: 7 Jul 2015 13:45:01
Message: <web.559c0f58952282f0b426f96a0@news.povray.org>
> >> ahem...
3.7 official.
The attached shows artifacts present at various accuracies for the function
sqrt(x*x+y*y+z*z)-1. max_gradient set to 100 for all spheres, which is more than
enough.
The first might look acceptable... but just try adding a pattern displacement,
and it'll become obvious that the accuracy is set too high.
I'd say that earlier versions simply had a high default accuracy or something,
but I remember getting sharp results along with fewer artifacts. IDK. I brought
it up a long time ago, and for a response I got crickets chirping. Oh well, it
was never enough to keep me from using POV-Ray :)
BTW, about that C++ compiling stuff I was going on about yesterday... I was
*mostly* joking. While I /have/ found myself compiling/recompiling SFML for
hours on end while making modifications to its source, there's no way I could be
replied upon to do such things as an occupation. My abilities in that field
exist within a very narrow range. Not sure what you do exactly, but I'm willing
to bet that if I had your job, I'd be as bald as Yoda due to all the hair
pulling, and much less wise :/
Download 'isospheres.png' (73 KB)
Preview of image 'isospheres.png'
Date: 7 Jul 2015 13:55:55
Message: <559c12ab$1@news.povray.org>
>> This of course is thwarted by functions that are extremely steep at the
>> edges, yet quite shallow near where the solutions are. [*cough*
>> Mandelbrot set *cough*] You end up needing an insanely high
>> max_gradient, yet in the vicinity of the solutions you could actually
>> afford to take much bigger steps.
> One thing that helps is to use log log smoothing for the exterior. It helps, but
> it's slow. And I could never find a successful way to multiply or divide a
> fractal's gradient in order to speed things up.
Yeah, simply dividing the function by a constant makes the maximum
gradient smaller, but also makes all the sample values smaller as well,
resulting in identical performance. Whereas taking the log (or even log
log) makes the steep parts less steep, while not affecting the shallow
parts very much. But, as you say, the log function itself is quite slow.
I wonder if a piece-wise linear curve would be any faster... (Not that
POV-Ray can do that.)
Date: 7 Jul 2015 14:00:01
Message: <web.559c1285952282f0b426f96a0@news.povray.org>
It all depends on what you want, but personally I don't like the idea. Even if
that sample was added to three others (forming a camera-oriented tetrahedron),
there's still a likelihood that those last DE samples will have been taken at
different relative distances to the surface across the render. Does that make
sense?
Hmm. Are you talking about breaking up the DE into separate regions, so that no
particular region will have too many components (shape operations)? If so, what
happens when a shadow or reflection ray needs to travel between regions?
Date: 7 Jul 2015 21:33:04
Message: <559c7dd0$1@news.povray.org>
Am 07.07.2015 um 19:55 schrieb Orchid Win7 v1:
Not? Well, you'd be surprised...
Even if POV-Ray didn't have its "select()" function, I guess some
creative use of "abs()" could get you there.
Date: 8 Jul 2015 03:43:57
Message: <559cd4bd$1@news.povray.org>
> 3.7 official.
> enough.
Assuming you've got no pattern displacement in any of those images, it
looks to me like it's something to do with the shadow ray being started
too close to the surface (and hence the tracer immediately thinks the
shadow ray has been blocked by the isosurface itself).
Date: 8 Jul 2015 03:53:28
Message: <559cd6f8$1@news.povray.org>
> sense?
Indeed, my personal goal is to rather keep the scene moving at a decent
frame rate (whilst adding more complexity) rather than towards a more
realistic render.
Yes, I'm thinking that with complex scenes I am still always computing
the distance field for every single object. What I think would speed
things up is if you could group objects together and create a kind of
much simpler conservative "group" distance function. I guess a kind of
n-tree structure where you only need to do a relatively cheap check at
each level to rule out certain nodes that you don't need to go down and
evaluate any further. I guess POV does something similar.
You would do this for every distance field evaluation, so it wouldn't
matter if a ray jumped from one region to another.
I'm also not sure if such a scheme would actually make much improvement
on a GPU.
Date: 8 Jul 2015 13:20:00
Message: <web.559d5a77952282f0b426f96a0@news.povray.org>
> > sqrt(x*x+y*y+z*z)-1.>
I should have guessed that, since I ran into shadow ray problems last summer
with the raymarching stuff. The shadow ray's origin had to be spaced from the
initial hit point (by backing it up toward the camera or outward from the
surface), or else artifacts would appear.
Attached is the same scene, this time with no_shadow applied to the isosurfaces.
Making the light_source shadowless also works.
I vote for a new keyword addressing this issue! Not only are the artifacts ugly,
but I would imagine they also slow down render times when aa is used.
Download 'isospheres-ns.png' (69 KB)
Preview of image 'isospheres-ns.png'
