POV-Ray : Newsgroups : povray.off-topic : 3D Glass Sintering Server Time
22 Jun 2025 06:44:38 EDT (-0400)
  3D Glass Sintering (Message 1 to 10 of 13)
Subject: 3D Glass Sintering
Date: 13 Nov 2013 13:05:01
Message: <web.5283be5aa8fcaec489b5ac30@news.povray.org>
I just watched a video on youtube demonstrating a 3D solar printer that uses
sand as a sintering medium.  The sunlight is focused through a set of large
Fresnel lenses onto a hopper into which sand is loaded.
The machine is designed so that the hopper moves around while the focal-point
remains stationary, but it occurred to me that the same effect might be achieved
with a gantry-style printer using a series of fibre-optic cables to carry light
from a parabolic reflector.
A similar setup was used to create a solar-powered laser scalpel.
http://news.bbc.co.uk/2/hi/science/nature/3111705.stm
thaughts?
A.D.B.
Subject: Re: 3D Glass Sintering
Date: 13 Nov 2013 18:50:01
Message: <web.52840f714f86b267372521a10@news.povray.org>
Fiber optic cables might even make the setup more accurate.
I love the whole idea! Any technology that reduces our need for petroleum
products is OK in my book :)
Sam
http://blog.stylesight.com/wp-content/uploads/2011/07/dezeen_The-Solar-Sinter-by-Markus-Kayser_08.jpg
http://www.robaid.com/wp-content/gallery/art-n-tech/solar-sinter.jpg
http://static.dezeen.com/uploads/2011/06/dezeen_The-Solar-Sinter-by-Markus-Kayser_09.jpg
http://4.bp.blogspot.com/-zXQCLKLbX9Y/TiBAvhOq9KI/AAAAAAAAATc/FqUYKP9hV9I/s1600/IMG_1218.JPG
Date: 13 Nov 2013 19:15:00
Message: <web.5284156e4f86b26789b5ac30@news.povray.org>
> Sam
The only thing I can think of that might be a problem is getting a beam of the
right intensity without melting the optical fibre.  The temperature at the focus
would have to be somewhere between 500 and 1500c
A.D.B.
Date: 13 Nov 2013 19:48:58
Message: <52841dfa$1@news.povray.org>
Am 14.11.2013 01:12, schrieb Anthony D. Baye:
>> Sam
Maybe take a bunch of fibers instead, and at the business end make them
all point at the same spot?
Date: 13 Nov 2013 21:00:01
Message: <web.52842cef4f86b26789b5ac30@news.povray.org>
> >> Sam
possible.  I had thought of that: you could run the cables to a single head
containing a collimator.  Even then, the cables might need to be replaced every
so often.
The advantage would be not having to keep your collector next to your sintering
machine.  Optical Fibre only loses 5% intensity per 1km, which works out to 1%
every 200m, so with relatively short distances, it shouldn't matter very much.
if you could use the light to drive an actual laser, it might be even more
efficient.
A.D.B
Date: 14 Nov 2013 13:25:01
Message: <web.5285151b4f86b2671353ccf10@news.povray.org>
> efficient.
Has anyone ever converted direct sunlight into a laser? Or by "laser," do you
actually just mean "parallel light beam?"
Date: 14 Nov 2013 14:33:23
Message: <52852583$1@news.povray.org>
Am 14.11.2013 19:23, schrieb Samuel Benge:
>> efficient.
Lasing media are typically pumped (i.e. supplied with energy to emit
actual laser light) by some kind of conventional light source - so why
not sunlight?
Date: 14 Nov 2013 15:25:01
Message: <web.528530934f86b267942c68130@news.povray.org>
> >> efficient.
> not sunlight?
Never said it wasn't possible; I was just wondering it anyone had actually made
it work :\ Also, why would laser light be better than simply using parallel
rays?
Date: 14 Nov 2013 15:49:06
Message: <52853742$1@news.povray.org>
Am 14.11.2013 21:20, schrieb Samuel Benge:
>>>> efficient.
>> not sunlight?
> rays?
I guess seriously parallel rays are difficult to achieve in the first
place - with one notable solution happening to be the laser.
To achieve parallel rays with optics - whether conventional or fiber
optics - you either need a sufficiently point-like light source, or one
that's far away enough to appear sufficiently point-like. The sun
doesn't really fit that bill. Light from some other star would probably
be fine, if it wasn't for the lack in intensity.
Date: 14 Nov 2013 17:30:00
Message: <web.52854d934f86b26789b5ac30@news.povray.org>
> > >> efficient.
> > not sunlight?
> rays?
http://www.technologyreview.com/news/408698/solar-powered-laser/
"They work by focusing sunlight onto crystalline materials, such as
Neodymium-doped Yttrium-Aluminum-Garnet..."
I don't see any problem with modifying the system to use an independent solar
collector connected with Fibre-optic cables.  There are already collectors like
that used for providing natural light during the day to indoor spaces, and I've
read that the light in the cable is so intense that it can start fires if
connected improperly.
A.D.B.
