POV-Ray : Newsgroups : povray.off-topic : Need to put a picture here Server Time
25 Feb 2026 19:13:21 EST (-0500)
  Need to put a picture here (Message 1 to 10 of 40)
Subject: Need to put a picture here
Date: 31 May 2012 16:50:01
Message: <web.4fc7d88ed2fa96b4a3bfeb720@news.povray.org>
No way to put a picture into the Bug-Report area. I'll put it in here and use
the link.
Here the Thread:
http://news.povray.org/povray.bugreports/thread/%3Cweb.4fc41d4a403c23aca3bfeb720%40news.povray.org%3E/
Rgds,
Holger
Download 'half_cpus.jpg' (203 KB)
Preview of image 'half_cpus.jpg'
Subject: Re: Need to put a picture here
Date: 7 Jun 2012 01:18:07
Message: <4fd0398f@news.povray.org>
Showoff.
Though it, and even my own 8-effective-CPU computer show a significant
problem with the interface of Task Manager's Performance tab:  just
squishing more and more graphs into the space horizontally results in a
pretty well useless display.  They should break it into several rows as
well.
Date: 7 Jun 2012 03:54:09
Message: <4fd05e21$1@news.povray.org>
> well.
A more significant problem shows up with my quad-core system. As you
know, it has 4 execution cores. But it also has hyperthreading, which
makes Windows pretend that it has 8 cores. But it doesn't. Which means
that even when all 4 cores are working at maximum capacity, Task Manager
claims I'm only using 50% CPU. This is terribly misleading...
(OTOH, Windows doesn't track how much CPU power is /really/ being used,
because there would be way too much overhead.)
Date: 7 Jun 2012 06:55:03
Message: <4fd08887$1@news.povray.org>
Am 07.06.2012 07:18, schrieb Tim Cook:
> Showoff.
> well.
You need to get a larger display :-P
Date: 7 Jun 2012 07:17:51
Message: <4fd08ddf$1@news.povray.org>
Am 07.06.2012 09:54, schrieb Invisible:
Claiming that it uses 100% CPU would be misleading as well. After all,
hyperthreading /does/ add some speed benefit; it pretty much depends on
your application how much that benefit is: The more cache misses the
software generates, the higher the HT benefit.
Even technically, HT indeed extends each core by another "half a core".
Date: 7 Jun 2012 07:28:34
Message: <4fd09062@news.povray.org>
And that, right there, is the problem. It would be prohibitively
expensive to actually /measure/ how much of the available compute
resources you're really using. So you have to guess.
Personally, I think I'd go for reporting all 4 cores running a single
thread as "100%", and then if hyperthreading kicks in, you go above
100%. My CPU goes up to 11! :-D
Date: 7 Jun 2012 07:30:07
Message: <4fd090bf@news.povray.org>
>> well.
http://cdn.overclock.net/8/8e/8eca552d_64Core2TBTaskManager_58CD8842.png
Looks like multiple rows to me...
Date: 7 Jun 2012 07:48:51
Message: <4fd09523@news.povray.org>
Am 07.06.2012 13:30, schrieb Invisible:
Hell's bells! Now /that/ looks like a machine I'd love to use for
rendering :-P
Date: 7 Jun 2012 07:56:24
Message: <4fd096e8$1@news.povray.org>
> rendering :-P
56 cores? Pffft. My GPU has 196 cores... ;-)
Date: 7 Jun 2012 08:08:51
Message: <4fd099d3$1@news.povray.org>
Am 07.06.2012 13:56, schrieb Invisible:
>> rendering :-P
Yeah, but can it run POV-Ray? :-P
Besides, just think of the scene complexity and radiosity quality you
can achieve with 2 TB of main memory...
