POV-Ray : Newsgroups : povray.off-topic : I give up rendering... Server Time
11 Sep 2025 11:09:40 EDT (-0400)
  I give up rendering... (Message 31 to 33 of 33)
Subject: Re: I give up rendering...
Date: 27 Jan 2012 11:26:46
Message: <4f22d046$1@news.povray.org>
>> I believe the 200 series is supposed to be the first release to support
>> CUDA.
> I don't think so.  It also works on older ones, but without many cores, the
> speed improvements are kinda negligible.
According to Wikipedia, CUDA is supported from the GeForce 8000 onwards.
So yes, my 260 should support it. (I've got the older 192-core version,
rather than the improved 216-core one.)
I doubt any number of cores would be small enough for the speed increase
to be "negligible"; a GPU core is much simpler than a CPU core, so it
does a hell of a lot more work per clock cycle. However, Wikipedia does
say something about the amount of video RAM being an issue with older
cards...
>> Isn't it in the main build yet?
> I'm not actually sure, have not followed up latest developments.  But it's still
> beta software that was announced about august last year.
OK.
>>> Here's a nice test scene:
>> Nice scene is nice. But I shudder to think how many decades it would
>> take on a twenty-PC render cluster...
> A few hours on your average PC.
Heh. I doubt it. ;-)
> Notice though that unbiased rendering
> supposedly never halts:  it improves the image gradually, removing noise as it
> goes.
Sure. I meant "how many billion hours do you have to run it before it
stops looking horribly noisy?"
>>> No povray wood is good enough on close-ups, it simply lacks the grain.  Even
>>> with noise or combining with other texture...
>> This is not my experience.
> I see grain in the wood of my tabletop that I never saw in povray wood, even
> good ones like the one in Warp's tips on realism... the difficult here is that
> the grain follows the direction the pattern flows...
Well, all I can say is it looked pretty convincing to me.
> If you from far away, you only notice the typical wood pattern, but close
> enough, you miss this thing.  And if you only intend to look from far away, no
> problem with "blurriness" for bitmaps.
I have yet to see any game with bitmap textures of high enough
resolution that you can't clearly see the pixels, even with all the
anisotropic filtering. :-P
> BTW, this is something that is visible in marble too:  looking close, you see
> there's lots of tiny crystal facets shining through just bellow the surface and
> you can't fake that with a mere texture.
Not if you don't design it into the texture, no. But if you do design it
in... yes! ;-)
Date: 27 Jan 2012 18:06:37
Message: <4F232E00.30401@gmail.com>
On 27-1-2012 16:19, nemesis wrote:
> Invisible<voi### [at] devnull>  wrote:
>>>>> If your gpu is a new nvidia, it can run on it,
>>>>> if not, just cpu.  But it's rather fast even on my humble dual-core at work, so
>>>>> should do just fine on yours.
>>>> nVidia GeForce 260 GTX. Is that new enough?
>>> I meant that it's CUDA-based.  Should work.
>> CUDA.
>> Having said that, I have repeatedly tried to make CUDA-enabled
>> applications work, with no success. Perhaps it will work under Windows
>> 7, but it never worked with Windows XP...
>>> You can find blender builds with Cycles here:
It should be from 2.60 on, latest release is 2.61.
I haven't tried it, I only use it as a modeller. Building models that
never see the light of day.
BTW it also now includes a camera tracker. You can include your own
footage, let the software decide what are nice points to track or give a
number yourself. After that you can include your own models in the
footage. Remember Rune's floating sphere projector
(http://runevision.com/3d/anims/hologram.asp#video)? That, but now
accessible to any 5 year old.
tip: do not run in an unknown place when it is too dark to see the
floor, unless you prefer to not use uppercase.
Date: 28 Jan 2012 00:50:43
Message: <4f238cb3$1@news.povray.org>
On 1/27/2012 3:49, Invisible wrote:
> disadvantage that it takes up gigabytes of storage, and looks blurry as hell.
Actually, the primary disadvantage that I find is that the texture tends to
repeat, and hence looks artificial.
   People tell me I am the counter-example.
