POV-Ray : Newsgroups : povray.off-topic : I give up rendering... Server Time
11 Sep 2025 11:09:42 EDT (-0400)
  I give up rendering... (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: I give up rendering...
Date: 25 Nov 2011 13:46:52
Message: <op.v5imf4e8ufxv4h@xena>
On Fri, 25 Nov 2011 06:18:29 +0200, jhu <nomail@nomail> wrote:
> http://www.youtube.com/watch?v=-_IKqjb9TRY&feature=colike
> This is the Titanic recreated in Cryengine 3. Holy crap! And it's better
> than
> what I can do in Povray...
I'm sure that if you can get the same models you can do a render that
looks better with pov-ray.
It may take a couple of weeks to render though...
-Nekar Xenos-
Date: 25 Nov 2011 14:19:30
Message: <4ecfea40@news.povray.org>
  Actually if you had the same models, textures and lightmaps as the
game engine has, it wouldn't take all that long to render. After all,
the scene consists of a bunch of meshes and lightmaps. That's very light
to raytrace.
  If you wanted soft shadows, that would take a little longer, but not
a whole lot.
Date: 26 Nov 2011 06:00:01
Message: <web.4ed0c59f34184307c4586f720@news.povray.org>
> One thing where the real-time engine has an "unfair" advantage is that
> the radiosity is pre-calculated [...]
No it's not. Cryengine3 renders global illumination in real-time!
http://www.youtube.com/watch?v=FqeXuO2AlEE
http://www6.incrysis.com/Light_Propagation_Volumes.pdf
Date: 26 Nov 2011 06:40:00
Message: <web.4ed0cfb7341843079a1bcfb90@news.povray.org>
Oh, thanks.  I was going to clear that up.
In any case, here's what I found:
http://freesdk.crydev.net/display/SDKDOC4/Static+vs.+Dynamic+Lighting
Scanline tech has come a long way thanks to massive investments from such a
thriving industry.
Date: 26 Nov 2011 07:32:17
Message: <4ed0dc51@news.povray.org>
  Since all the lighting in the titanic scene is static, calculating
lighting dynamically is an enormous waste of resources. That exact same
scene could be rendered just with static lightmaps. (Turning lights on
and off does not require dynamic lightmaps, it just requires switching
between alternate sets of precalculated lightmaps.)
Date: 26 Nov 2011 08:05:00
Message: <web.4ed0e22034184307c4586f720@news.povray.org>
I know. Still, the engine is capable of rendering global illumination in
real-time and that's what it does. The fact that it is able to do that makes me
doubt that there are any resources being wasted ;)
Though, I assume the calculation heavily relies on reusing samples from scene
parts that have not changed, thus saving calculation time.
Either that or deciding which parts to reuse is actually more time consuming
than just re-rendering everything from scratch each frame.
Anyway, it works, and it's real-time.
The point being: Whether the scene is static or not, there were no
pre-computations!
Date: 26 Nov 2011 13:59:24
Message: <4ed1370c$1@news.povray.org>
I was under the impression that it only approximates GI using
screen-space methods.
...or not...
http://blog.orphi.me.uk/
Date: 26 Nov 2011 17:48:43
Message: <4ed16ccb@news.povray.org>
The definition of loser is thinking you're beaten before trying your
best. Evolve as a POVer and when you think you are good, try even
harder, try to be an expert and you can be an expert and then can't
think of a way to render that Titanic then give up...
Date: 27 Nov 2011 09:36:43
Message: <4ed24afb@news.povray.org>
Or as Master Yoda says ... Do or do not, there is no try ;-)
Date: 27 Nov 2011 11:05:00
Message: <web.4ed25fa7341843079a1bcfb90@news.povray.org>
And what do you call one who looks at a joke and takes it seriously?
Surely enough povray can render real reflections and GI with more than 1 bounce
with radiosity -- though as the Crytek guys noted, 1 bounce is good enough for
movies. For bonus with povray folks, you could even render a complete CSG
Titanic made up from boxes and cylinders.  But surely enough the video shows how
amazing to be able to do it real time with graphics that look good enough
running on off-the-shelf hardware rather than some renderfarm.
